Question about Baby Gear
1999 gmc sierra 1500 4wd 5.3 engine light blinking and truck running rough
I put new spark plugs and new wires, but my truck keeps shaking and engine light is still on.
  • 2,039 Answers
You need to get the code number after i gonna have and idea thank pierre
Posted on May 12, 2008
1993 gmc sierra 4wd runs rough after engine warms up.At stop lights she will stall out if i dont keep foot on break and give a little gas. any suggestions ?
Question, does this pickup blow black smoke on idle or at a stop sign. If so check your map sensor might be plugged up or unplugged or bad.
Mar 05, 2014 | 1993 GMC Sierra K1500
Replaced engine coil, drove for 50 miles and check engine light starts flashing along with the motor running very rough unless my foot was on the gas petal, replaced EGR valve and still doesn't want to...
cap ,rotor ,spark plug wire , spark plug could misfire....
the check engine light flash because it's a severe misfire and fuel go to converter catalyst.
Sep 29, 2013 | 1998 GMC Sierra
1993 gmc sierra k2500 rough idle with fan on
Normally I would say the a/c compressor is pulling on the engine causing a cylinder miss. The miss is probably there all the time, just worse with the a/c running. But it should do it when in a/c mode too.
The compressor runs in defrost mode to dry the air blowing on the windshield.
I would check for a bad spark plug or plug wire.
Jun 26, 2012 | 1993 GMC Sierra K1500
Hard to start, runs rough. hard idle. truck shakes when idling
Check the resistance of the plug wires, the gap on the spark plugs along with their condition and check the primary and secondary resistance of the coil. Willing to bet you have 2-3 plugs not firing due to gap or bad wires.
Nov 07, 2009 | 1997 GMC Sierra
After washing truck check engine light came on.
let up hood let it idle to dry watch the check engine light . it should be okay.let it idle it will smooth out.
Apr 12, 2009 | 1990 GMC Sierra
1985 gmc sierra shakes
Nic, If the carburetor was dumping gas, remove the engine oil dip stick and see if it smells like gasoline. If it does you will need to change the oil.
Second, go back over your spark plug wires and verify they are on the correct spark plug. Start with the #1 plug wire, the firing order is 1,8,4.3.6.5.7.2...
Let me know how it turns out and we can go from there.
Good luck.
Feb 26, 2009 | 1985 GMC C2500
Cold rough idle and engine light flashed
Spark plugs/wires might need to be replaced. Check your spark plug gaps and check your spark plug module harness connection on both sides of the engine. The check engine blinking indicates short/misfiring. If there is short in the harness, you can check it by moving around the wires close to connector one by one while the engine is running. You might need to remove and ckean the Throttle Body.
Dec 02, 2008 | 1999 Chevrolet C2500
I have a 1998 GMC 1500. For several years now I have experienced the same problem over and over. The check engine light comes on and eventually the truck starts running very rough. I have taken the...
resistance in plug wires ... degrades them. I find this as a standard GMC Sierra problem. Two sets on mine already. Coding is for misfires. Also, possible to unplug your MAS [mass air sensor] which will keep the 'check engine' light on at all times but it will no longer be in the circuit and could also be another solution to the problem. Changing out O2 sensors is just expensive since there are Banks A and B and each bank has 2 sensors. The cost from a part store is 80$+... hate to know what they charge you at a garage.
Go with the new wire set first.
Sep 22, 2008 | 2003 GMC Sierra 1500
Baby Gear Logo
91 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
