Question about Fujitsu Siemens Computers & Internet
Shortly after switching on (varies 1-3 mins) the computer goes into sleep mode.on switching on again all carrys on from where we left off
  • 629 Answers
You may want to check power options in the OS and disable hibernation and set the power options as desired.
Posted on Sep 01, 2010
Unable to turn off music in sleep mode
Hi, There are different levels of sleep a computer goes through as time passes and it can take a while for your computer to fully awaken. What happens is the computer closes programs not necessary in sleep mode. Some of the small programs used to carry instructions called batch files are in hibernation and especially in older computers with slower processors and very little ram can be a problem. You can set your computer to never sleep by going to the control panel and opening Power Settings. Good Luck
Feb 05, 2014 | Acer Computers & Internet
Computer won't come out of sleep
Sleep Mode Problems on a Dell Computer b> When Microsoft patched the power-saving features of Windows XP Service Pack 3 and Windows Vista, certain Dell computers were affected by various issues where the computers would go into sleep mode and be unable to come out of it or error out and not go into sleep mode. Sometimes the computers would go into sleep mode and wake up only when a USB mouse was jostled. Pressing keys on the keyboard would not wake the computer because the keyboard would stop functioning
Open the Dell support page on your Internet browser. See the link Below . http://support.dell.com/ Make sure to have your seven-digit alphanumeric (letters and numbers) service tag. Place that information into the "Choose by Service Tag" option. Make sure that the option for the "Operating System" is correct. Go to "+Bios" and click on the "+" symbol. Click on "Download" at the far right, save and run the downloaded file. Restart your computer after installing the file. Test the "Power-saving" feature once you have rebooted. b> If Section I Does Not Resolve the Issue Go to "Display Properties" by right-clicking in an open area on your desktop and left-clicking on "Properties." Click on the "Settings" tab. Check if the "Display" midway down is saying "Plug and Play Monitor on..." If it is not, go to the "Device Manager." Left-click on the "X" in the top right corner of the "Display Properties" menu. Go to "Start," left-click, and then open the "Control Panel" (or "Settings" and then "Control Panel" depending on your system is set up). Select "System," go to the "Hardware" tab, and left-click on it. Left-click on "Device Manager" about 1/3 of the way down that page. Look at "Monitors" and see a "+" symbol. Left-click on it once and see if it has an exclamation point,"!," with a yellow circle around it. If it does, right-click on the "Plug and Play Monitor" and left-click on "Update Driver." Choose "Yes, this time only" and then left-click on "Next." The wizard will update the monitor drivers automatically, if possible. Restart if necessary once updated. Test the"Sleep" mode again. The computer should go into sleep mode and then wake up successfully. b> If Section I and II Do Not Work Left-click on "Start" and then "Control Panel" (or "Settings" and then "Control Panel," depending on your system's setup). Double-click on "Power Options" to open it. Open the "Hibernate" tab and click on "Enable Hibernate." You may have to reboot again. Test the "Sleep" mode function again. b> Windows Vista Open the Dell support page in your Internet browser. See the link Below. http://support.dell.com/ Make sure to have your seven-digit alphanumeric service tag. Place that information into the "Choose by Service Tag" option. Make sure that the option for the "Operating System" is correct. Go to "+Bios" and click on the "+" symbol. Click on "Download" on the far right. Save and run the downloaded file. Restart the computer after installing the file. Test the "Power-saving" feature once you have rebooted. b> If Section IV Doesn't Work b> Reboot the system and press "F2" or "Del" to get into Bios. Make sure that the "Legacy USB" option is enabled. Save and exit the Bios and start Windows Vista. Go to "Start" and then "Control Panel." "Switch to Classic View" on the left side. Click on "Power Options." Click "Change Plan Settings" and then "Change Advanced Power Settings." Set the "Sleep>Sleep After" to "Never." Set the "Sleep>Allow Hybrid Sleep" to "Never." Set the "Sleep> Hibernate After" to one minute after the monitor and hard drive are set to turn off. Set the "Power" button and "Lid>Start" menu power button" to "Hibernate." Restart the computer and test the "Power Sleep" mode. b> If Section IV and V Do Not Work b> Find the "Windows" sidebar at the bottom right corner. Right-click on it to disable it. Test the "Sleep" mode again. If the computer does go to sleep, enable the "Windows" sidebar by going into the "Control Panel" and enabling it again. Start turning off each gadget one by one, and test the "Sleep" mode to see which gadget is causing the problem. Look at the system and see if you have a "Google" sidebar." If you do have Google sidebar, then pick only one to use, or choose not to use either of them. To remove the "Google" sidebar, left-click on "Start," then left-click on "Control Panel." Double-click on "Programs and Features." Wait for the computer to populate installed software on your computer. Find the "Google" sidebar and remove it by left clicking on it and left click "Uninstall." If you want to remove the "Windows" sidebar, right-click on it, left-click on properties to open "Properties," then remove the check from the "Start Sidebar When Windows Starts," selection and click "OK." Disable Sleep Mode Microsoft Windows 7 uses sleep mode for desktops and laptops to save power during times when the computer is not in use but does not need to be shut down. Sleep mode pauses and suspends your computer until you are ready to continue. In some cases, sleep mode interferes with scheduled tasks or operations such as remote desktop connections. Microsoft allows sleep mode to be turned off and disabled for users that have no need for the function or find that the feature is interfering with their normal computing activities.
Click the "Start" button to expand the Windows "Start" menu. Select "Control" panel in the right column of the "Start" menu and click "System and Security." Click "Power Options" and press the "Change Plan Settings" link next to your computer's currently selected power management plan. Select "Never" from the "Put The Computer to Sleep" drop-down menu. Select "Change Advanced Power Settings" beneath the "Change Settings For The Plan" heading. This launches a "Power Options" panel. Double-click "Sleep" in the menu tree to expand the advanced "Sleep" options. Select "Sleep After" and use the arrow to select "Never." Select this option for both "On Battery" and "Plugged In" if you are configuring power options on a laptop. Click the small "plus" icon next to "Hibernate After" to view hibernation settings. Click the arrow to select "Never." Select "Never" for both "On Battery" and "Plugged In" if you are configuring your power options for a laptop. Click "OK" to close the advanced power options. Select "Save Changes" to save your new power management configuration. Your computer's sleep mode is disabled.
Hope it helps.
Jan 25, 2013 | Dell OptiPlex 760 MT Desktop Computer
My Samsung Notebook 700Z screen goes to sleep after 1 Min. I have checked and re-checked my settings, and it is set right. Any suggestions?
Disable the hibernate mode and standby, uncheck hibernate on left, then sellect never on all three in power settings.
Sep 24, 2012 | Samsung Computers & Internet
Screen Turn's on.You seen Acer load up Splash Screen for less then a min, Stay on until Windows Xp Load up screen then goes into sleep mode. Encontered same problem when I connected Xbox360 with HDMI to...
  • Hello chaleebradsh, the "Monitor" as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. "I hope this information is of help; thanks for using FixYa, paul7of9"
Jan 31, 2011 | Acer AL1717 17" LCD Monitor
What is 1/4 moon symbol on top left of my compaq keyboard ? when i press it seems to put my computer into sleep mode . how do I get my computer started again ?
You are correct. The moon is sleep mode. Closing and opening the lid will often take it out of sleep mode. You might have to "unlock" the keyboard as well by entering a password (just hit return if you haven't entered a password.)
Under power options, you can select what the computer does in sleep mode.
Jun 20, 2009 | Compaq Keyboard
Computer not sleeping in sleep mode.
One possibility is if you have an optical/laser mouse that is on a relective surface and the mouse light is reflecting and triggering the computer to think that there is activity.
More than likely, your network card is keeping your computer from staying in sleep mode as any internet data activity is taking the computer out of sleep mode making the computer think there is activity.
There is an option in the Network Adapter properties that says to "Allow this device to wake up your computer"
Go to Control Panel and click Classic View on the left hand side
Double Click the Network and Sharing Centre Icon.
On the left hand side of the window that opens, click Manage Network Connections.
Right Click on the connected Network Connection. It is probably the Local Area Connection. Right click on it and choose Properties
A new box will open up. Click the Configure button under the Connect Using: box
Click the last tab at the top that says Power Management.
Under the Power Management tab click the square box that is beside: Allow this Device to Wake the Computer to take the checkmark out of the box. Then Click OK at the botton and close all the windows.
Let the computer go into Sleep mode and see if the computer still comes out of sleep mode on its own.
Let me know if this worked for you,
Ry
Apr 03, 2009 | HP Computers & Internet
Delay in Monitor display once the system goes in sleep mode
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
Feb 06, 2009 | Gateway Computers & Internet
Laptop goes into permanent sleep mode, etc
If you can restart it and it starts up fine, then I would go into the power settings and disable sleep mode. Every computer is different on how to wake a sleeping computer, so you could read through your manuals and find out for yours, but I just disable sleep mode on all computers so i dont have to hassle with it.
Dec 30, 2008 | Computers & Internet
Computers & Internet Logo
224 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
