Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Top drawer of dishwasher is making really loud"motorlike" sound. sounds like something is **** in the motor? Just started out of the blue.
  • Fisher and P... Master
  • 3,247 Answers
The noise could be coming from the motor assembly. It is the grinding sound of rotor roughing against some hard food particle in the rotor cavity. Most likely a chicken bone or seed.
Take the rotor out and check. Refer to user manual for checking rotor cavity. It is possible the rotor may be damaged in which case you will need to replace it.
Posted on Sep 26, 2010
DS603 fisher paykel motor noise when starting up
The pump and motor for DD603 is the same device. It is a rotor lodged inside a cavity under the drain filter plate. I am assuming the dishdrawer is drained properly and at end of the wash there is no water sitting inside. You need to take the rotor device out from its cavity and check for damage. This video will help.http://www.youtube.com/watch?v=UXzuJvKIIgU
Mar 26, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Very Loud Noise when dishwasher starts
It is likely the sound is coming from the rinse aid dispenser solenoid. (I am assuming you do not have a water softener unit on your dishwasher). Try to run the drawer on a Rinse cycle and see if the noise is still coming.
Apr 21, 2013 | Fisher and Paykel 23 in. DD603H SS...
Dishwasher is making a loud noise
Sounds like there is something in the filter trap that is right before the mini disposal that is a fan blade, on top of the motor.
Aug 04, 2012 | Frigidaire Professional Series 24 in....
Dishwasher has starting making a real loud noise when running. sounds like it might be the motor or bearings or something! Still working fine, it's just very loud!!! Andy ideas?
It could be the motor bearings, they can go out if the pump seal starts to leak and moisture gets to the motor bearings. If that is the case you are looking at about $180.00 for the sump and motor (parts only).
It could also be something caught in the sump near the chopper that is creating the noise. Here is a link to some clean out instructions if you are up for trying them.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a Fisher/Paykel dual drawer dishwasher and the top drawer now makes a loud grinding noise - appears to be coming from the front of the unit. Any thoughts? Any home-based solutions?
Remove dish rack, spray arm, remove filters, remove the rotor (under the spray arm) Check if the rotor itself is making any sound or not rotating freely when you turn the impeller on the top. Replace if needed, otherwise - carefully check for debris.
Nov 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenwood quiet guard dishwasher just started making a LOUD vibrating sound that seems to be coming from the front top of the door during the cycle. i think it has something to do with the draining...
HI, there are two impellers that can become stripped or jammed overtime. the drive shafts will continue to spin in this case, causing this grinding sound you hear.
You will need to inspect the during housing and the circulation motor as well for signs of impeller trauma. replace each impeller if found to be separated from its respective housing or shaft.
it is required to remove the sump assembly to access the cirulation(wash) motor.
Jun 19, 2009 | Kenmore 24 in. 15162 Built-in Dishwasher
Dual dishdraw bottom Ok, top one wont start cycle,F2 comes up
Try swapping the motor rotors between the two drawers and see if the fault changes drawers, also check for anything stuck under the motors or and damage to the plastic of them. cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer of dishwasher has a loud pump noise while running
Look for burrs on the botom impeller of the rotor. it requires no tools to check this. Take the wash arm and filter plate off, now rotate the motor rotor's base counter-clockwise and pull it out. Inspect the greay impeller closely for any nicks or burrs. If any are present, the impeller will make a LOT of noise. If it needs to be replaced, you can find them at fisher paykel parts, here is a link to the part you will need:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=9
Nov 23, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Kenmore 665 Quitguard7
I have the same dishwasher, It is probably something like a small piece of class or plastic stuck in the food grinder. If u take the bottom wash are off then the grinder cap u will see the grinder. take it out and clean it, should solve your problem
Aug 01, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher Dilema
You need to remove the bottom drawer and dry out the water with towels and a hair dryer when this is done it should operate normally. most likely when you pulled out the drawer the water sloshed back and out of the drawer making the dishdrawer think it was flodding turning on all drain pumps. If you look at the back of the drawer about two inches from the floor you will see an oval hole off center to the right. That is where the water got out.
Jan 10, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
826 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
