Question about Dell Latitude CpX Laptop PIII 500 Mhz 13.3" TFT 10 GB HD 128 MB RAM CD Floppy 56K Modem Internet and... (DCPX500CD) PC Notebook
Wont power on
I turn on my laptop and only three lights come on for 5 sec and then turns off hard drive does not spin, fan doesnt go on either.
  • dempros4u Jul 09, 2008
    I have a Dell Latitude CPx Laptop, and when l put it on, the fan spins for seconds and stops. Sometimes when l leave the machine off for days and put it on, the fan spins till l put it off. And the Keyboard makes beeps when you type anything.
  • 3,940 Answers
Try powering the system on with only the AC adapter, see if you get any power indications.
If you do not, then the system is not getting AC power.
See if the power adapter has an LED on it and if it is lit with the computer disconnected. If the LED doesn't come on at all, replace the adapter. IF the LED is on with the computer unplugged from it, then goes out when you plug it in, then try a new AC adapter.
If a new AC adapter doesn't resolve the problem, then you may want to look into buying a new computer as replacing the motherboard on this system may cost more than replacing the computer with a new system.
Posted on May 16, 2008
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Laptop Does not Boot
your hard drive might be fried so I'd advice you to take it to a pc shop
Dec 31, 2012 | Computers & Internet
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
Cant operate bios after reformatting the unit
If you cannot operate the BIOS, the best way is to reset the CMOS battery which require a very good technician to tear down the unit. Here are the steps:
Turn off laptop
remove cables and battery
Press and hold power button for 5 secs.
Remove screws in the edges of the laptop
Remove Hard drive, Optical Drive and Power supply fan
Press the CMOS battery (circle shaped silver coating) upwards so that it would disengage and put it back in...
Put back the Hard drive, Optical Drive and Power supply fan
Put back screws in the edges of the laptop
Put in cables and battery
Turn on laptop and the BIOS will be reset successfully...
Jan 09, 2011 | ASUS A8HE-4P017C (90NNVA4115384CAL301) PC...
My HP Pavillion laptop g61 wont turn on or off. There is no fan running it doesnt sound like it is on but the power button light is on and wont turn off. The screen just stays black. I have tried charging...
I had trouble looking up that model on the HP page, but you should check this page and see if this model is affected by this NVidia litigation. If it is, you can get it fixed/replaced on NVidia's dime.
http://www.nvidiasettlement.com/affectedmodels.html
Oct 15, 2010 | HEWLETT-PACKARD Pavilion G61631NR Notebook
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
How do I know if my Directv HR22-100 HD receiver is dead?
one last thing you can do, if it doesnt work the dvr is dead. reset the dvr and wait for the hello screen and then the screen will go black. when it turns black, hold the down arrow (on the front of the dvr) and the record button for at least 5 secs. this will re-format the hard drive. if it doesnt work the dvr is dead
Jan 02, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Dell Latitude CpX Laptop PIII 500 Mhz 13.3" TFT 10 GB HD 128 MB RAM CD Floppy 56K Modem Internet and... (DCPX500CD) PC Notebook Logo
107 people viewed this question
Alun Cox
