Question about Saeco Odea Go
Saeco odea steamer is leaking
I have had the machine for a few months and the steamer just started leaking (fairly quickly when the coffee is brewing and after)... any ideas?
  • Anonymous Jul 15, 2008
    descaled several times
  • pmozen Jul 15, 2008
    leaking wand saeco odea
  • 3 Answers
This is a known issue with the Odea GO. You need to take it in for servicing to get the rubber seals changed. This happened with our maching after about 6 months.
Posted on Mar 09, 2009
  • 74 Answers
Its the casket in the Tpipe that has gone bad.
Posted on Jul 11, 2008
I have a Saeco Giro that leaks coffee under the machine
check the brew unit .there is something wrong with "O" rings
Oct 07, 2014 | Saeco Odea-Giro Espresso Machine
Saeco odea giro flashing light
Alarm light:
permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the drip tray is full.
on and slowly fl ashing (one or more events): signals that the Brew Group is not
inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed,
the service door is open.
•on and quickly fl ashing: signals the need to prime the water circuit.
Jun 24, 2014 | Saeco Odea Go
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
We have an Odea Giro in the office. When we got it I remember the coffee tasted amazing. After few months the taste started to decline and after some time we stopped to use it altogether. I wanted to...
you are supposed to go through the "before first use" instructions....which include filling the resevoir with water and brewing only water until its all gone. then start using the machine normally...remembering that the machine takes a few brew cycles to adjust properly to the coffee being used (this assuming this is the giro plus model which has the feature-"aroma something or other...)
also, descaling would help and removing the brew group and rinsing it out...
Nov 23, 2010 | Saeco Odea Giro Plus Coffee Maker
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Nov 14, 2009 | Saeco Odea Go
My Saeco Odea Go always seemed very noisy?
maybe pump make noise,check holder of pump,or replace pump
Aug 29, 2009 | Saeco Odea Go
No owners manual
Here's that manual - the English section starts on p.96:
http://www.wholelattelove.com/manuals/Saeco/Odea%20Giro%20Full.pdf
Actually, this is a fairly complex espresso maker - I don't even see a clock on it.
-Tha Mp3 Doctor
Mar 26, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro - Clogged and coffee come out in water tray....
This has happened to our machine that we use for our youth group. We sent it in and they said it was clogged also. Not having a clue what they meant. It happened again and I figured it out. When you remove the brew group there is a hole just above it that dispenses into the brew group. Make sure it is not clogged. Give it a try Good Luck
Mar 08, 2009 | Saeco Odea-Giro Espresso Machine
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
772 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
