Question about Brother XR-35
I actually have a Brother XR40 sewing machine (not XR35). I get a nice stitch on the bobbin side of the material, but not the top. The top is more like a straight thread anchored down and not a nice definite stitch. I can't find my owner's manual. The machine is threaded correctly. What can I do to get a nice stitch on the top and the bottom??
Hello.
I own a Brother XR-40 Sewing Machine.
I can not figure out how to select straight stitiching in the display area.
I only see #17 Feather Stitching.
It appears that it is locked into its memory.
Help!!!
Denice
San Antonio, Texas
Posted on Oct 28, 2012
  • Denice Braziel Oct 29, 2012
    Thank you. Your answer solved my problem!!!!
  • Brother Master
  • 7,365 Answers
Check to see if the needle is bent-roll it on a flat surface & see if it rolls correctly
if the needle is warped it will make a popping sound when it goes thru the fabric
check to make sure the tension is correct
check to make sure the thread is not catching on anything
I went to the brother website they have a manual in pdf format you can download for free
1.go to brother website
2.click on home sewing & embroidery
3.on the page on the left go down to product manuals &
click on it
4.on the page it will show home sewing & embroidery &
select model----xr40
5.click on view
6.go toward bottom of page-YOUR RESULTS-USER MANUALS
ENGLISH & SPANISH
7.click on user manual-english & spanish & the download will start- if you have fast internet it will take a few minutes
slow will take a little while
Posted on Sep 01, 2010
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
Stitch issues
Find the tensions on your machine. Usually a screw below on the bobbin regulates the top stitches tension. Usually a numbered wheel on top--where the thread is around it--regulates the bottom stitches. YOU NEED TO ADJUST THE TOP WHEEL, test on scrap material, and if looser, you are in the right direction. If it is still a mess. turn the knob to a lower number.
Apr 04, 2014 | Brother CS6000i Computerized Sewing...
The bottom stitching looks like a line and not stitches the top stitching is fine
whether its bias or straight does not matter to machine. loosen the bobbin tension and put more tension on take up spring by inserting a screwdriver in the slot of the top thread tensioner. turn to right.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
Thread tension
try changing the needle first--make sure the needle is the correct one for the fabric being sewed.
if you've adjusted the top tension & the bottom stitch still looks the same
it's possible that the top tension dial is needing to be checked to see if it's
working correctly
Apr 17, 2012 | Brother CE4000 Computerized Sewing Machine
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
The thread on the top side of my material starts looping after 4-5 stitches. I've tried every number of thread tension, and even on 0 it loops on the right side of the material, not on the back.
Check the tension on your bobbin thread. When you hold it by the thread and let it dangle does it just drop down without any resistance at all? If so then you need to tighten it a bit. If the bobbin thread is too loose it can not pull the top thread down enough thus puts the loops on the top side of the stitch.
Feb 25, 2011 | Brother LS2125i Sewing Machine
How do i adjust the bobbin tension on a tesco ej09 sewing machine? The bobbin thread keeps tangling underneath the material
Before adjusting the bobbin tension (small screw on the side of the bobbin case), try this.
Always thread a sewing machine with the presser foot up as this opens the tension control for the top thread so the thread can be properly seated for control when stitching.
Often what appears to be a problem with the bobbin thread is actually the top thread going loosey-goosey.
Apr 03, 2010 | Sewing Machines
Loose stitch with loops on top of material i got the right needle and bobbins what do i need to do i have ls 2125 brother
General rule of thumb is this.. If it loops on the bottom the problem is on the top..
If it loops on the top, the problem is on the bottom.
Sounds like #1 your bobbin is wound very loosely , #2 your bobbin thread has to go thru its tensioner.
Apr 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Sep 10, 2008 | Brother LS-1217 Mechanical Sewing Machine
Open Questions:
Sewing Machines Logo
426 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
