Question about Sony Cyber-shot DSC-W50 Digital Camera
Shutter button broke off
Can i fix this myself, or do i need professional help?
  • Anonymous Jun 04, 2008
    Love this camera but the shutter button broke off...
  • 797 Answers
If the button has come out, then it may be that the parts which hold it in are broken, or other damage internally.
One suggestion is to buy a camera like it with another problem such as lens problems.
Trade the parts necessary.
Other option is to have it repaired. That may cost more than it is worth..
Posted on Aug 04, 2008
This analogue AL-1 Canon camera do not take a picture when pressing shutter release button. I guess it is because the button to the wheel located inderneath is stuck for some reason. Can I fix this myself...
From your video I can't tell whether the shutter is cocked. Can you crank the film advance lever all the way and then press the shutter release button?
Apr 03, 2013 | Cameras
Plastic shutter button broke. Can release shutter by pushing in the middle but button is gone includeing screw int piece for shutter release. Is this an easy fix?
The only easy fix is to glue with a super glue with the broken part or parts. If this is lost then you need to fabricate a similar type knob to be glued into the slot making sure that glue does no overflow and get the whole shaft stuck.
other wise the original can be sourced or replaced from a worn out/discarded camera or consult the Pentax service for estimation.. to restore it originally.
Jan 25, 2011 | Pentax ME Super 35mm SLR Camera
Replace Sony Cyber-shot DSC-W55 shutter button
Don't throw your Sony Cyber-Shot camera away!
We found a website who has created an entire comprehensive photo instructions for the Sony Cyber-Shot DSC-H Series Shutter Button Installation.
They also have the Sony Cyber-Shot DSC-H9 Shutter Button Installation Instructions as well!
Please note that we STRONGLY recommend using a flash discharger. This is for your safety and also for your camera's safety.
Hope this helps to get your camera working and start capturing memories again!
Aug 18, 2009 | Cameras
Nikon d60 shutter release error
press shuter release button again
Jun 22, 2009 | Nikon D40x Digital Camera
DSC-h1 Shutter button broken
I recieved my new shutter button from Sony and replaced it after searching on the net how to do so. I used rubber gloves to get a good grip on the button ring and turned it, I believe clockwise, and then replaced the it with the new button and ring. So simple and saved myself a lot of $$ though, $30 seems an awful lot for such a small piece of cheap plastic.
Sep 04, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Shutter button on Sony camera
Hey melboz,
You can purchase a replacement shutter button from the manufacturer for about $18 and I have included a link to the part for sale at Sony. If the camera is less than a year old the repair could be free thru the manufacturer, but I am assuming this is not the case since Sony is telling you they want $140 to fix it. I have never replaced this shutter button myself but from what I can tell by searching the internet it is not too difficult to do yourself. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 11, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
How to reattach shutter button
The fix is real easy. No need to take the camera apart.
Order the Shutter Button Release Assembly from Sony. Cost was around $18.00 + tax + Shipping. I received the new assembly in one week.
Note the angle of the old assembly before removing it so that you can line up the new one correctly.
To remove the old button assembly, use a rubber bottle opener to get a good grip. Turn slightly counter clockwise. Then use your fingernail to lift it up. Look inside using a magnifing (sp) glass and find the pieces that broke off, a spring, a small plastic tip and a small snap ring.
Look at the opening and you'll notice two slots, that's where the two little feet will line up. Again using the rubber bottle opener and pressing down slightly, turn the newassembly clockwise. You'll feel it.
Make sure to clean out the pieces that broke off. I couldn't find the spring, now I can't use that little wheel to bring the viewfinder into focus for my eye. LCD is still sharp as are the pictures. Just the viewfinder.
Good luck.
glenn gorman
Sat, 18 Aug 2007 18:50:55 +0000
Whoops: x21083252
Sony Direct Accessories
May 07, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Stuck shutter release button on my D100
Ouch...
The damage may require parts, but maybe not. If I were doing the work, I would charge in the $50-$60 range , plus parts if needed.
Nikon will likely quote you much higher $200+
You can use the repair service locater here on Fixya to find a repair shop in your area
Mar 24, 2008 | Nikon D100 Digital Camera
Shutter button repair
hi it depends on where it broke and if...(the button) if it just fell then u can just take the new button a shove it in untill theres a CLICK if its broke then u will need to pull out the rest and then shove it in DO NOT TRY TO OPEN THE CAMREA IF U DONT KNOW HOW!! you will brake the pins inside when u will and then it will cost u as a new cam good luck windman
Feb 14, 2006 | Canon PowerShot SD200 / IXUS 30 Digital...
Sony Cyber-shot DSC-W50 Digital Camera Logo
229 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
