Question about Avaya 5610 IP Phone
There are two ethernet jacks plus one phone jack on the bottom of the phone. I don't have directions for connecting, and there are no visuals in Avaya's manuals. How do I connect?
    Sergeant:
  • 284 Answers
There are 3 sockets 1) ADJ Socket 2)Phone 3)PC
Posted on Sep 01, 2010
Can a security system be run off magic jack
It should work just fine as long as you are not using the old MagicJack or a newer one via USB connection to through a computer as our will create too much of a latency or delay to operate properly. It should be a newer model connected directly to a router via the Ethernet connection.
Feb 19, 2015 | magicJack Two, 2 Magic Jack Plus Voip...
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
Where do i find the ether net connection
It is on the back of your tower. It looks like a phone jack.
May 20, 2011 | IBM ThinkCentre A50p PC Desktop
My d link router will not connect to the internet from my phone jack. I where I receive my phone and internet connections. What steps do I take to install to receive the highh speed connections?
The phone jack must be connected to a modem, which is then connected to the router via an ethernet cable. To connect:
1. Connect the phone cord from the jack in the wall to the jack in your modem of choice. Turn on the modem. 2. Connect a CAT-5 ethernet cable from the correct jack in the modem to the correct jack in the router. 3. If using a wired connection, connect an ethernet cable from the router to your computer. Otherwise, simply activate the wireless card of your computer and select from the available wireless networks.
Mar 11, 2011 | D-Link Office Equipment & Supplies
I need to know how to hook up a westell versalink ? i dont have directions & i have a dial up connection on my desk top . do i need a server ? i have no idea what to do !!
In order to setup the versalink you need an active DSL account, a phone line cord, a phone jack, a pc or mac, and an ethernet cord or wireless ethernet card. Plug in the phone cord to the phone jack and to the DSL port on the versalink- once the DSL light is solid, plug in the ethernet cord to the computer you have, or enter the wep key on the bottom of the modem into the wireless manager for your system. At that point, if you need further assistance in getting online, contact Verizon or Bell (whichever is your DSL provider)- they can and will walk you through setting up the versalink to connect to the internet.
Oct 03, 2010 | Westell Wirespeed VersaLink...
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect to internet thru ethernet jack on computer
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
Jan 05, 2009 | Dell Dimension E521 (D10E16) PC Desktop
Help
It sounds like you may be trying to connect the ethernet cable to the TELEPHONE jack, which is used for a telephone line, and connects to the modem in your PC.
If equiped, the ethernet jack is similar to the phone jack, but it is wider, and will accept the ethernet cable. Please look for this on your PC.
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Avaya 5610 IP Phone Logo
87 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
