Question about Whirlpool MH7140XF Microwave Oven
My Whirlpool Microwave Hood Combination model #MH7140XFQ-0 will cut off in 2 to 3 seconds when I add a minute or punch in the time. Everything still works-light comes on, table turns, time is still showing.The fan still comes on when I press the button. It just turns off and says 'power start?' with the time still there. I tried pressing on the door to see if that would help. What do you think? Jim
  • 537 Answers
SOURCE: whirlpool mh7140xfq
Does it make any noise, like buzzing ? Is there a burnt smell? If so it might be a shorted diode or perhaps the magnetron.
Posted on Oct 21, 2008
ginko
  • 19396 Answers
SOURCE: microwave not working
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken vent grille for a Whirlpool microwave hood combination
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Posted on Jun 06, 2009
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: whirlpool microwave hood combination has code f2
The F2 error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On these models, usually the membrane keypad is not available separately, so you would have to order and replace the control panel frame which comes with a new keypad (sometimes called "panl-cntrl").
The part availability and cost will depend on the full model number from the tag on the unit, and it will be one of these:
MH1150XMB0
MH1150XMB1
MH1150XMB2
MH1150XMB3
MH1150XMB4
MH1150XMQ0
MH1150XMQ1
MH1150XMQ2
MH1150XMQ3
MH1150XMQ4
MH1150XMS0
MH1150XMS1
MH1150XMS2
MH1150XMS3
MH1150XMS4
MH1150XMT0
MH1150XMT1
MH1150XMT2
MH1150XMT3
MH1150XMT4
You can order the part and find helpful exploded view diagrams here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Jul 11, 2010
MISSING OWNERS MANUAL FOR MODEL gh4155xpq-0 Microwave
Do you mean the Whirlpool Microwave Hood Combination GH4155XPQ0? Most Whirlpool appliance manuals are available here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . The direct link to the manual for the GH4155XPQ0 is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208204919.pdf .
Sharp doesn't have a microwave with this model number. If you gave the incorrect model number but the correct manufacturer, please add a comment with the correct model number.
I hope this helps.
Dec 03, 2011 | Microwave Ovens
I have a Whirlpool MH7140XFQ-0 Microwave and last night it stopped working with the screen showing F6. I unplugged it for over an hour and plugged it back in and it went right to F6. It tries to run if the...
"F6" on a Whirlpool microwave means you have a shorted cook relay on the control circuit board.
For model MH7140XFQ0 the control circuit board would be part number 4393919, which you can order from the Pros here for $132.23.
Then you unplug the keypad (as per the photo below) take out the old board, then move the new circuit board into your frame.
Otherwise, we regularly repair these boards with our $39.95 nationwide service. Details are here.
Jan 23, 2011 | Whirlpool MH1140XMS Microwave Oven
MH7140XFQ Fuse Amp
you need to look at the ends on your fuse and this will tell you the amperage you need to get for your particular unit,get them from a hardware store
Sep 22, 2009 | Whirlpool MH7155XM Microwave Oven
Jun 06, 2009 | Whirlpool GH8155XJ Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
I need User Manual for my microwave
Just click below;
Whirlpool Microwave/Hood Combination manuals, user manuals, owners ...
Whirlpool Microwave Hood Combination MH7140XF, YMH7140XF User Guide Get This Manual .... Please help find the manual for this Black & Decker Convection Oven ...
Hope this may help you; DON'T FORGET TO RATE:
Sep 06, 2008 | Whirlpool MH7140XF Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
253 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
