I have recently purchased 2 used Eiki LC-XT4 12k projectors. When I have both projectors on with a blue screen (or image), the menu on the first one is within the border of the blue screen, however, on the second one, the menu is outside of the blue screen, specifically it is outside of the top margin. This means the blue screen fits perfectly on the screen, however the menu is projected above the screen onto the black valance. I believe this to mean that my blue screen (and image)is somehow being cropped, as the edge of the menu should define the projection area.
CompuGuy44
  • 432 Answers
SOURCE: Borders outside printable area
Adjust the margins in the software you are using.
Posted on Jun 26, 2007
SOURCE: The image projected from my CTX EzPro 680 Projector flickers on screen
From my experiences working with projectors, more than likely you will need to replace the lamp
Posted on Oct 31, 2007
  • 208 Answers
SOURCE: Coloured Pixels in or around black areas when watching TV
This is know as a diffusion issue. Most times this can be corrected with some minor alignment on the pots on the YSUS pwb. Sometimes the YSUS pwb has failed and will need to be replaced.
Posted on Feb 04, 2008
SOURCE: Problem w/blue "bleed" on LCD TV screen
Sony has acknowledged this problem as being a defect in the optical block and has extended the warranty replacement on this part till december 2008. I have the kdf50we655 and had the same problem. It was repaired for free, but would have cost me about $1500.
Posted on Mar 23, 2008
SOURCE: SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Posted on Jul 09, 2008
Eiki LC-XB23 Projector vertical bands top to bottom of screen
almost sure 1 or more lcd panels are defective
sorry, but than it is end of life for this projector.
May 20, 2012 | Eiki LC-XB23 Projector
Eiki LC-XC1 color problems
check all the optical parts around the blue lcd-panel, they might be darkened due to heat
May 07, 2012 | Eiki Office Equipment & Supplies
My Eiki lc-xb33 is projecting the image from my computer very dimly. Although the image is in focus, it is very difficult to see the image at all because it is so dim. Even the blue start up screen is...
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
May 11, 2011 | Eiki LC-XE10 Projector Multimedia...
I have an eiki lc-xb42 that i just mounted upside down. how do I convert the image upside down?
in setting menu choose the icon with the upside down R ,press select and
with arrow keys select ON, picture shuld be OK now. No need to safe just press MENU.
Nov 12, 2010 | Eiki LC-XB15 Multimedia Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
Projector remote
go into the menu under settings. should find lamp hours under there. as for the remote, try www.projectordoctor.com
Nov 10, 2009 | Eiki LC-X1100 Multimedia Projector
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
Eiki LCSB Projector: no input
make sure the resolution matches the input.
Sep 14, 2008 | Eiki LC-SB20 Projector Multimedia...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
