Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Power board Do you happen to know approximately how much it cost to buy a power supply board?
  • jrcoxusa May 14, 2008
    The TV repairman told me I needed a new board.
    He also said it was difficult to find.
  • 22 Answers
Power suply boards can range in price. The most i've seen was $289.00. I've seen cheaper. Are you sure you need a power supply?
Posted on May 14, 2008
TV turns on but powers off after approximately 1 minute. Any suggestions?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 22, 2015 | Televison & Video
I own a LT 42E488 42' flat screen JVC for last three years it has been mounted. we took it off the wall and back on it's stand. connected everything back and ......nothing....the TV makes the clicking...
This tv problems are 90% to 95% is it a dying power supply board.Power LED light indicator blinks or tv take a really long time to come on.The tv problems indication are the power supply board have dying capacitors parts,it usally or alway bulges up or puffing up onto it tops and leaking,not giving the tv power supply voltages correctly anymore to the rest of the tv other boards.The tv power supply board,that the board,where the power a/c cord plug into it.The tv shop,will charges u like 600-700 bucks,they'll repair the board or they'll put in another refurbish power supply board for the tv.U have some basic mechanical skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board to do the replacement ur self.The cost of power supply board like $100-150 bucks plus shipping the part to u.The take out and the reinstallation of the power supply board it pretty easy and straight forward,if u willing to take a chance and putting in some labors.
Apr 26, 2011 | JVC LT42E478 42 in. HDTV
Does apower supply cost the same as a main board for a samsung TV
never!
power supplies are the lesser of the two evils- usually, depending on model, the power supply costs is approximately $100- 180.
if you have a Samsung that just clicks, a relay clicking sound on and off on and off...it is a simple repair that can be done for less than $20 if you can work a screw driver and have a soldering iron.
Apr 12, 2011 | Samsung Televison & Video
LG LCD TV there no display on screen. Service person says it SNP(power supply) card has to be replaced as its supplying more current to PCB & cost is Rs. 6000. I would like to know whether the...
No power LED light indication to the tv screen panel at all or LED light power indication flashes?Yes,it is the power supply board have problems.Tries websites like Shopjimmy.com,Ebay.om to buy a refurbish power supply board for the replacement.Refurbish power supply board cost about usally $100-$110 plus shipping.
Sep 28, 2010 | LG Televison & Video
Turning on the Power
Your power supply board needs to be REPAIRED not REPLACED, replacing the board will just make the problem happen again in two years or less, if you can use a screwdriver you can send me the board and I will repair it for less than it would cost you to do it yourself ($50) with the correct components. Email for further instructions! Cory Schindler cschindler24@yahoo.com
May 30, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
I don't have any power to the t.v. even though it's pluged in to the outlet. It's a emerson model EWL20S5B?
Small TVs like this almost always are made up of two boards inside - a power board and a main TV board.
And almost always there's a fuse on the power board, near where the power cord goes in.
Checking that fuse is the only thing you can do by yourself.
Your next option is to give the TV in for repair to someone who fixes such things. Chances are high the problem is in the power supply board and is repairable.
However, the cost for doing so can be prohibitedly high as cost of the TV itself is prohibitedly low. I mean you may be better off selling it on eBay for $50 and buying a new one.
I know I'd buy it for $50 there.
Nov 17, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Power supply aux power connection burned out
If this happened on three supplies, the trouble has to be in the motherboard connector. Probably one of the pins is corroded or very loose and causing a poor connection. The resulting heat is melting those connectors. You would be best off replacing the board since you don't know if other problems may be waiting to occur. A replacement would probably cost around $50 to $60.
Feb 20, 2009 | Asrock 775i65G Motherboard
PC won't power on at all.....
If you get no fans or lights on either the keyboard or frn of the machine, I would suspect a bad power supply. They are fairly easy to change.
Jun 14, 2008 | E-Machines eMachines Desktop PC
Protron 42" tv
I would suggest to search for customers reviews of this product if you can google it. Personally I have not own one of this TV, I only service them.
I think LCD's and Plasmas are newer technology and the designers and manufacturers still trying to make them better. If you buy one of this TV, try buying the extended warranty if possible.
In regards to the power supply repairs, It could go from about $85.00 to $125.00 or it could be more expensive if you're buying a new board.
May 22, 2008 | Protron PLTV-32 Television
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
60 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
