Question about ASUS (SL1000) Router
I have a 3 wired connections, two of which utilize VPN connection to Mayo Clinic and Microsoft. We have a 7mbps DSL connection operating at approximately 6mbps. We have intermittent slowing of internet speeds. We have been unable to determine the cause. We suspect 1) we are over utilizing the connection we have and require a second dsl line. 2) the modem is not sufficient for our use (Qwest Tech support has suggested we purchase a PK5000 by actiontech) 3) we do not have the router set properly. Is there any suggestions you can give to help us Isolate the cause?
  • 94 Answers
SOURCE: Can't use internet wirelessly through router
You need to connect the line cable in your dsl modem the the router and go through the set-up procedure on the router.
I.E. put all your ISP settings into the router.
Posted on Jul 31, 2008
Testimonial: "Info was very helpful"
  • 67 Answers
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Posted on Dec 10, 2008
  • 135 Answers
SOURCE: i keep getting disconnected from my companty's vpn
- Check the Internet if working properly?
- Access the configuration page of your router and open the firewall settings, uncheck the list below:
Enable PPTP Passthough
Enable L2TP Passthough
Enable IPSec Passthough
- Try to gather some VPN ports to open using the router.
Note: You should have your permission from the connection of VPN to use it.
Posted on Mar 05, 2009
  • 65 Answers
SOURCE: Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Posted on Aug 23, 2009
SOURCE: have just purchased a RT-N16 wireless router and I
Did you get this problem solved? I too am having the same problem with the same router.
Posted on Jan 19, 2011
Mayo clinic symptoms
We need much more information. But, what does the mayo clinic have to do with a modem?
What are the symptoms on? Is it a modem or a person?
Jun 24, 2014 | Computers & Internet
I have a Linksys 2 wire router. My DSL connection
it could be a lot of things giving you trouble
fisrt check if your connection is droping from the isp
if so contact isp
second check lights on modem such as power dsl and internet
3rd think of a modem remplacement
Jan 15, 2010 | 2wire (1000-400108-001) Router
VPN Connection problem with DSL
contact your ISP and ask them to enable IPPAssTHROUGH on your system.
make sure the ports::
TCP 10000
UDP::500, 4500 should be open
Mar 30, 2009 | SonicWALL Global VPN Client for PC
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Configure VPN
That 3Com really doesn't have a wahy of setting up a VPN.
As per the 3Com site it:
Support of VPN termination/initiation and passthrough allows secure connection to central office and/or secure access from remote workers.
So it will allow 3rd party VPN setups to pass through, but it doesn't have the ability to create one.
You might want to look into something like a Netgear Firewall
Aug 09, 2008 | 3Com OfficeConnect Cable/DSL Router 4 x...
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
ASUS (SL1000) Router Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
