Question about Car Audio & Video
Mybrother played a trick on me and changed my code and forgot the password
Panasoniccq-vd6505u mobiletv dvd player
  • ghettosuspec May 10, 2008
    my car tv code was changed and i can't use my tv now it is a panasonic cq-vd6505u
  • 111 Answers
While code request mode,Just press and hold the skip up switch >>I for about 30 sec. and the display Will show ****,release the switch and display will show WARNING and then will go to tuner mode.
At this point the code will be cleared and you can program a diff rent code.
Thank's for rating
Posted on May 10, 2008
How do I restore Toshiba DVD player SD3990 back to original without password? Forgot password.
If you forget your 4-digit code
If you forget your password, to clear the current pass-
word, follow the procedure below.
1 Press SETUP to display the setup menu.
2 Use the Number buttons to enter the 6-digit number
"210499".
The 4-digit password is cleared. "P CLr" appears on the
display for a moment.
3 Enter a new code as shown above to the left (Rating)
Dec 05, 2014 | Toshiba SD-3990 DVD Player
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
Cq-vd6505u Car DVD Player is locked i need the code to unlocked thank u this is a panasonic brand
You can try to hold the right round selector knob to the right for 10 seconds while unit is on asking for code input. That will work to unlock if the previous owner did not set the 4 digit code. Good Luck
May 26, 2010 | Car Audio & Video
Kenwood ddx-6019 password
i think you find some softuare on ebay to unlock your radio....i m not 100% sure but you can take a locke
May 28, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Panasoniccq-vd7001u
Are the blue lights at least coming on? Do you have the remote?
Nov 21, 2007 | Panasonic CQ-VD7001U Car DVD Player
I cant get the parental lock off of my dvd and it wont play any movies at all
Try this. The mintek dvd 2580 password " screen " looks like it wants four numbers, it actually wants five numbers. And they are 88888 as set by the manufacturer. Unless someone has changed it from its original password. If you ever need the code for the remote it should be 0717 . I hope this helps.
Aug 31, 2007 | Coby TF-DVD7333 Portable DVD Player
Input password screen
i believe that the problem is in the movie itself it has a password somewhere on the case try playing it on antoher dvd , c if it does it agian windman
Jan 30, 2006 | RCA RC6001P DVD Player
Car Audio & Video Logo
147 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
