On every print job, there is a paper jam in the trey. it seems that the only problem is that the top sheet of paper is not being picked up by the roller. i use the manual feed trey instead.
  • 1 more comment
  • Jack Sep 01, 2010
    i should mention that the machine is a Brother MFC 9840 CDW, about 2 yrs old.
  • Jack Sep 01, 2010
    cleaned all the rollers - 1st time did not work, 2nd time appears to have worked,
    Thanks for your help.
  • Jack Sep 01, 2010
    Thank you. the 2nd cleaning worked.
  • 2,973 Answers
The top sheet of paper is not being picked up because the paper sensor may not be functional. The stack of paper is supposed to be pushed up and the top page is pulled in by the rollers. Try cleaning the rollers with moist (not wet) soft cloth. These are rubber rollers and can be rolled and cleaned. Do that please. Paper jam is caused by the rollers. Please clean the rollers. All of them, wherever you can reach and see the rollers. Dirty rollers cause jams.
Posted on Sep 01, 2010
Samsung SCX 4623F " Paper Jam Inside"
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 05, 2016 | Office Equipment & Supplies
My HP5200 13.20.00 Paper Jam
sounds like your fuser sensor or the fuser is bad
Jul 28, 2017 | HP LaserJet 5200 Printer
My HP 2600n printer always jams if there is more than one sheet in the paper tray. If there is only one sheet in the tray, it never jams but if there is more than one sheet, the first prints and while its...
Hello ,
The pad of solinoied become teared & only gum left on solenoied by which on the paper picking proces it fix on the base,by which the picking rooler continious mooves & pick another paper & become jam.so clean that path & remove the gum & paste the tape .your problem will be resolved 100%.
jm
Sep 07, 2011 | HP Color LaserJet 2600n Printer
My Brother MFC-7820N has a paper jam problem that seems to be related to it's picking up an additional sheet of paper and when the first sheet completes it's print pass, the second is midway and the...
most paper has a smooth side and a little less smooth side, try flipping the paper. in the pack use the top side as the printing side when u load. try a different brand of paper could easily correct the problem,
some feed trays work best when nearly full also, try half full etc.
Oct 10, 2010 | Brother MFC-7820N Laser Printer
My Brother HL-5740 Is jamming after every print jog. It's pulling two sheets through, the first sheet with the print job and the second sheet clear, Its like every job has two sheets. The second sheet...
You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
Oct 16, 2017 | Brother HL 5140 Laser Printer
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
Paper Jam Error Message
I would try to clean the tires with alcohol, it's probably trying to pick up the other sheet but is slipping.
take out the tray and look inside for the pick-up and seperation tires.
Oct 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
54 people viewed this question
jasbo
jasbo
