Question about Maytag 30 in. CSE9000 Electric Cooktop
None of the 4 burners will ignite. There is a little sparking, and I can light the burners using a butane lighter, but the spark isn't enough to start the burner.
  • 2,272 Answers
The burner may not light if the ignitor is damaged, soiled or wet. The spark is not coming because igniter is weak. the problem with your oven is a bad igniter.
Let me explain how it works:
The igniter is wired in series with the burner valve. When the thermostat calls for heat, line voltage is applied to the circuit. As the igniter begins to glow, the current increases. The current flow causes the valve to open when the igniter becomes bright red (almost white). Flat igniters operate from 3.2 to 3.6 amps. In your case the current is less then 3.2 amps and even it does glow it does not open the gas valve.
Replacing the igniter should solve the problem.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 01, 2010
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Tip
Cooktop Range Stove spark ignition does not work
You go to light the burner on your cooktop and the spark does not work.
What can the problem be? In most cases the problem will be because the
spark ignition module has gone bad. This spark module is a piece of electronics that produces a harmless electric spark at 2-4 pulses per second. Because the spark is a ultra low amperage spark, it is not dangerous.
A typical spark ignition will look similar to this.
This box is usually in a metal box located somewhere under the cooktop of your stove or in the back panel of your stove. The easiest way to find this is to simply follow the electric wires that go from the spark ignition box to the spark tip located at each of the burners.
The spark is activated by a switch that is located behind each of the burner control knobs. When one of the switches is turned on, all of the burners spark at the same time. The spark switch will look something like this.
To troubleshoot the spark ignition you need to determine if the system is wired in series or parallel. If the system is a series system and one is not sparking, then none will spark.
Almost every time if the spark is not working, it is because of a bad switch. To isolate which switch it is, turn each switch till you find the one that does not activate the module to spark. You can confirm this by pulling the two wires off of the switch and touching them together. If you get spark you know that the switch is bad. If no spark happens then either then a wire is bad or the module is bad. If none of the switches cause the module to spark then it is a good assumption that the spark module is bad.
By checking through these procedures you will be able to tell whether your problems are caused by a bad switch, a bad wire, or a bad spark ignition module. You will discover almost every time that the switch behind the burner is the part that needs to be replaced.
on Aug 18, 2010 | Cooktops
Ge monogram ZGU366LPSS one burner does not light up
It will light with a lighter just not the igniter which means the igniter is not working, sometimes they crack and run to earth, remove the top and turn off the lights you will see it sparking where it's running to earth.
Mar 09, 2014 | Thermador Cooktops
A single glass electrode isn't sparking on our GE gas cook top. The other four burners all spark fine. There is a spark underneath the cover on this single burner - just not on the electrode on...
Is this one that you use all the time? Maybe it's dirty and you could try to clean it somehow. If that doesn't work, you could find another sparking anode at a dealer and replace it. A toothbrush or other stiff bristle brush of similar type should do it. In the meantime, you can use a lighter with the gas on low to light the unit.
Hope this is of help
Joe
Aug 31, 2011 | Cooktops
All 4 gas burners have stopped clicking at the same time. Fires up with lighter. Is this fixable
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Sep 08, 2010 | Magic Chef Cooktops
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
None of the four burners will ignite when the gas is turned on. The electric igniters don't spark. The gas comes out and can be ignited with a separate butane lighter. I believe the electric power is on to...
Check that electric power closely. A boil over and attempted re-start or water (or other liquid) leaked / spilled into an igniter switch can trip your GFI outlet. Sometimes the outlet the cooktop is plugged into is fed from a GFI recepticle further " up stream " so you may have to look around to find a GFI which has tripped.
Feb 08, 2010 | Cooktops
Burner not lighting
Yes, you need a technician. It could be spark module or spark igniters on each burner.
Dec 15, 2008 | Cooktops
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Cooktops Logo
95 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
