Question about Dell Computers & Internet
My key is stuck and will not work - Dell Computers & Internet
  • 166 Answers
Follow the link below to check if you can correct the problem
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=CD861594D80064A7E030A68F27285BBC
If you are unable to follow the above steps, call dell support center by following the link below
http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_us?c=us&l=en&s=gen&redirect=1
They will help you.
Posted on Sep 01, 2010
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
When pressing number on laptop its showing characters
From your description I must assume that if all other keyboard functions and keys work properly then the keyboard is faulty. For the number keys to print the upper case characters shown on those keys requires a shift key to be depressed or stuck. If all other keys work properly, replace the keyboard. Otherwise look for a stuck shift key. I have found keyboards for sale on Ebay.
Jun 19, 2014 | Lenovo ThinkPad Edge E430 Laptop Computer
2003 range rover ignition key off power still key stuck in position 1
some of these electric interlocks require the brake pedal stepped on for releasing..have you tried that? along with shifting fully into park a few times?
Jan 26, 2014 | Cars & Trucks
How do I release a stuck key in the key panel?
Chances are there is a stuck key on the keypad. Normally the only way to correct this issue is by replacing the overlay and keypad. Use your serial number to find the correct item for your version. http://www.sportsmith.net/
Dec 23, 2013 | Precor EFX 546i Elliptical Version 4
Keyboard stuck
If you are addicted to your laptop, or are an overzealous typist, you may be dismayed when a key on your laptop becomes stuck. However, just because a key gets a little sticky, you don't have to run out to the computer repair shop. There are plenty of practical steps you can take to fix your stuck key right at home that don't require any fancy equipment, just regular household items.
1.Clean the area around the affected key. Use a damp cloth to clean the surface of the key (and surrounding keys) and then use a dry cotton swab to clean under the stuck key. Be careful not to pry the stuck key up with the cotton swab, as this could break the stuck key.
2.Press firmly on the stuck key. Sometimes after small dust or particulates are removed, the stuck key will pop back into place. However, if this is not the case, continue on with Step 3.
3.Pull out the fingernail cleaner extension of your fingernail clippers. This is the flat extension with a little hook on the end. Place the small hook under the left corner of the stuck key. A common reason that keys get stuck is that the collapsible spring becomes off-center. Gently push the key from side to side until it clicks into place. If this does not happen, you will need to disassemble the key completely.
4.Lift the top part of the key with the fingernail cleaner. You will see a collapsible plastic hinge (this is known as the Key Retainer) as well as a little rubber piece. Take both of these out. You will see a flat surface. Run the cotton swab across this surface to remove any dust.
5.Place the key components back in the keyboard. Place the rubber part on top of the metal circle you just cleaned with the cotton swab. Then place the key retainer (big side down) on top of it, and "click" it into place. It is very important to be careful with this step as these small parts break easily. Then place the stuck key on top of these parts and then give it a solid tap to click it into place. Your key should work now.
Sep 28, 2011 | Computers & Internet
How to remove something stuck under a key on y computer?
Hello.
Hope this helps.
Sep 25, 2011 | Toshiba Satellite P105-S6197 Laptop
The O,L,9 keys are not working in my toshiba satellite M105-S3002 laptop., any help is a big tnx.
Hello.
• 1
• 2
• 3
• 4
• 5
Hope this helps.
Aug 02, 2011 | Joy Toshiba M105 S3002 Notebook
The middle c of my sx-k700 Technics keyboard is not working. How can i fix it?
Mar 14, 2011 | Technics Audio Players & Recorders
Error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
May 04, 2010 | IBM ThinkPad 390X 2626 Notebook
Cant shift into park and key stuck in ignition
USE A WRENCH AND STREACH THE KEY HOLE WORKED FOR ME!!!
Mar 26, 2009 | 1994 Mazda MPV
Computers & Internet Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
