Hello Skye, the Kenwood Multiple Compact Disc Player DP-MH5 of your dad, has a problem with a strap inside the mechanism, I suggest you take it to a specialized technical service
If you have technical knowledge, I send you the link to download the service manual, on page 16, the breakdown of the mechanics appears and shows you the belt with the number 46, that is the one that you must replace
I also sent you the link to download the user manual
Greetings Franco Dosil
Hola Skye, la Kenwood Multiple Compact Disc Player DP-MH5 de tu papa, tiene un problema con una correa dentro del mecanismo, te sugiero que la lleves a un servicio tecnico especializado
Si tu tienes conocimientos tecnicos, te envio el link para descargar el manual de servicio, en la pagina 16, aparece el despiece de la mecanica y te muestra la correa con el numero 46, esa es la que debes reemplazar
Tambien te envio el link para descargar el manual de usuario
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-DPMH-5-Service-Manual.pdf https://www.manualslib.com/manual/203920/Kenwood-Xd-8551.html?page=17
