Question about Kenmore Heating & Cooling
I need to get the front off of a wall conditioner to clean the filter It is a Kenmore...25,000 BTU....Model number 2538782594
5 Suggested Answers
  • 142 Answers
SOURCE: 18,000 btu kenmore wall A/C fins on back side of
There may be several reasons. First ensure the air filter is clean and not clogged with dirt. Second ensure the coil is clean and has good air flow. IF you did that then the unit may be low on refrigerant charge.
Posted on Jun 04, 2009
  • 3 Answers
SOURCE: DeLonghi A120 12,000 btu ar conditioner Leaks
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Posted on Jul 26, 2010
  • 413 Answers
SOURCE: How do I clean air
You first need to pull it out of the window
Then, take off the case which will require removing several screws and the "wings" that make it fit in the window.
Set it on the concrete or a sturdy outdoor table
The rear and front coils will be the most important things to clean. Water is the best way to clean, but it you use a hose and sprayer, you have to be careful not to get the electrical components wet.
You can also use a good vacuum cleaner if you have one that has a wand.
The rear coil can be loosed from the fan shroud by just a few screws and set back to where you can get to the rear of the coil. It will be stopped up with dirt,etc. Take the vacuum or water sprayer and clean rear coil thoroughly. The front coil can be cleaned from the front. A wire brush would help you out greatly. Be sure to clean out the bottom pan of the air cond also, so that the unit will be free to drain properly. Be sure, if you loose the rear coil from the fan shroud not to bend the tubing coming from the coil. Also if you are using water, let the unit dry out for an hour or so before you plug it back in.
Posted on Jun 25, 2011
MOTORWIZJ
  • 1340 Answers
SOURCE: How do I remove the front cover of my old Kenmore
THE FILTER SHOULD SLIDE OUT FROM THE SIDES OR THE TOP, AND SOMETIMES THE BOTTOM. JUST HUNT AROUND AND WITH THE TIP OF YOUR FINGER , DO THE WIGGLE TEST
Posted on Jul 28, 2011
How do I remove the front cover of my old Kenmore 5200 BTU window air conditioner to access and change the filter?
Jul 28, 2011 | Kenmore 75051 Wall/Window Air Conditioner
How many BTU is Model#580.74085 580.74124
8000 BTU. I have one. I'm looking for the EER rating, although I see an energy star label on the front.
Jun 19, 2011 | Kenmore 75135 Thru-Wall/Window Air...
I have a Kenmore 25,000 BTU unit; and, unsure if it was not properly installed. On the front in looking inside there is alot of white installation covering the vent. I don't think this is normal?
Is it cooling ok?
If this is a window unit, it sounds like you're looking at the filter, which would be ok, assuming it's not clogged. You should be able to pop off or remove the front of the appliance and see if the filter is dirty.
Apr 18, 2011 | Heating & Cooling
I want to know the most effecient height as to wall mount my Model LRA257ST2 25,000 BTU air conditioner. Is closer to the ceiling better?
Yes, closer to the ceiling is better. As, hot air rises and cold air falls. Just keep it about a foot off the ceiling.
Apr 06, 2011 | Frigidaire Heating & Cooling
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
18,000 btu kenmore wall A/C fins on back side of filter freezes up. Why?
Jun 03, 2009 | LG LP6000ER Air Conditioner
Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Mar 28, 2009 | Kenmore Heating & Cooling
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
23 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
