Question about Black & Decker 22" Electric Hedge Trimmer
JFS 22" 56cm hedge cutter with 26cc 2 stroke petrol engine and 180degree rotating handle
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
Have recently bought a 2 stoke ( 1 part oil to 50 petrol) hedge cutter. Prime it in start position 7 times as reccommended. But terrible problems starting it. Have used it 3 times and it takes up to half...
If you are not using fresh fuel, change the fuel and replace. Although you will still have fuel in the carburetor and the lines. If you do not remove and drain it may take a little while to get it to start, but should be a lot less then what you are doing now.
Aug 20, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
I have got 26cc homelite hedge trimmer what type of 2 stroke oil do i need for it, MANY THANKS
You can use any brand of two stroke oil as long as it says on the container that it is suitable for air cooled engines and you need to mix it at a ratio of 25 to 1. Regards Phil
Apr 19, 2011 | Homelite Garden
Oil/petrol mixture for GPHS 26cc gardenline hedge trimmer
Petrol / oil should be in ratio 50 to 1
Apr 13, 2011 | Garden
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
What mix of 2 stroke oil do I use for a Stihl hedge trimmer, in other words how much 2 stroke oil do I put into 5 litres of petrol. Thanks.
if using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
May 29, 2010 | Garden
MY MAKITA DPC6410 PETROL SAW IS RUNNING SMOKEY
It uses 2 stroke oil during combustion as it is a 2 stroke powered engine..Sometimes it may be a small deposit of oil and the bottom of the gas container which causes this smoke or else you may have added a bit more oil than needed in the fuel..I assume it is a 2 stroke engine and also note these do give out a little bit of smoke..
Dec 08, 2009 | Makita DPC6410 64cc 12" Power Cutter
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Dec 10, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Black & Decker 22" Electric Hedge Trimmer Logo
144 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
