Question about Nikon D1X Digital Camera
Ee erorr messege - Nikon D1X Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 02, 2010
Testimonial: "very inform thank you"
Note 3 won't sent any texts
check your messege centre no
go to messege setting and find out messege centre no
and confirm it with your service provider
for messege centre no call your sim provider customer care
Dec 26, 2013 | HTC HD2 Smartphone
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
How would I enter the following on this calculator? 9.1 EE -31 ? 1 EE 3
Do it exactly as you wrote it. For the negative exponent use the change sign key [ -]. The question is whether you are aware of the meaning of the EE key.
The EE key is a shortcut for x10^. Thus 1EE3=10^3=1000.
As to the other number (the electron mass) its value is 9.1x10^(-31) kg which you enter as you typed it 9.1 [EE] [( -)]31 [=]
Sep 01, 2010 | Texas Instruments TI-30XA Calculator
What does the ee symbol above the qoutation mark mean
What you call a quotation mark is in fact a comma. It is used to separate arguments inside commands that require more than one arguments, or the elements of a list.
The [EE] that you access by pressing [2nd][comma] is very useful in scientific areas of studies such as physics and chemistry. It is a shortcut for times 10 to a power.
If you want to enter Avogadro's number you enter
6.02[2nd][EE]23 [ENTER]
The electon charge is
1.6[2nd][EE] (-)19 [ENTER] . Here the (-) is the change sign key located between [.] and [ENTER]
The [2nd][EE] sequence must always be followed by an exponent even if exponent is 0.
Try these
[2nd][EE] 0 [ENTER] (Surprised? You should'nt be!)
[2nd][EE] 1 [ENTER]
[2nd][EE] (-) 3 [ENTER]
Hope it helps.
Nov 04, 2009 | Texas Instruments TI-83 Plus Calculator
When I square 10 it equals 1000 when i use the EE feature
To raise 10 to the 2nd power, if you do not have a dedicated key, you use the (^) or (X to the y) or (Y to the x) depending on calculator.
The EE key is a shortcut. It has another meaning
EE 0 = 10^0 =1
EE 1 = 10^1 =10
EE 2 = 10^2 = 100
Thus if you enter 10 EE 2 this is equal to 10 x EE 2=10x 100= 1000.
This is the correct way.
Hope you will remember it : It is the source of much grief to the learners.
Oct 08, 2009 | Texas Instruments TI-30X-IISTK Scientific...
When i enter 10 exp (-)2 equals, the calculator displays the result as 0.1 when it should be 0.01? why would this be happening?
The [EE] or [Exp] shortcut is the source of much grief to the students.
When you press the [Exp] 0 you are in fact entering 1.00 so
[EE] (-)1 [=] gives 0.1
[EE] (-)2 [=] gives 0.01
Thus
10[EE](-)2 is 10[x][EE](-)2 or 10[x]0.01 = 0.1
The new generation of calculators does not have the [Exp] or [EE] key. It is replaced by a key with a more explicit label [times 10 to the X]
Hope it helps.
Sep 23, 2009 | Casio FX-300MS Calculator
Fan Fail Erorr Fan:15 on m1500 Quantum DTL.
Replace broken fan, but before you do that open up your computer while it's running, and make sure all of the fan connectors are snug.
Jun 18, 2008 | Quantum M1500 (m1-2/21-s6l) Super DLT Tape...
RICOH 2027 SC792 ERORR CODE
This seems to be a finisher communication error. If you unit has a finisher on it check the connector.
May 26, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Open Questions:
Nikon D1X Digital Camera Logo
64 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
