Question about Bosch Dryers
My tumble dryer keeps tripping the electric - Bosch Dryers
  • Bosch Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is probably going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Jul 16, 2015 | Candy Dryers
Washing machine keeps tripping the electrics
you have bad circuit breakers in your house power center; replace them with the correct amperage value for your machines or, call an electrician
Feb 04, 2013 | Washing Machines
My tumble dryer keeps losing heat it still works and i have to keep pressing the button on the back of the machine for it to heat back up
take the vent tube off run dryer, it should not trip your button. You will need to clean the vent tube. Good Luck Tim
Feb 05, 2011 | SNK Knight 43AW Electric Dryer
Hotpoint tcl770 condencer tumble dryer, just out of warantee. when turn on and start it keeps tripping the electrics. changed plug fuse etc, tried in various sockets but keeps tripping the system???
internal problem, either heater coil or sensor or motor, you will need to get it checked, but don't plug it in again, as short circuits on high current machines can be dangerous.
Jan 14, 2010 | Hotpoint Dryers
It still heats up and has not tripped the breaker,
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 12, 2010 | Whirlpool LER5636P Electric Dryer
My Creda tumble dryer is not turning there is only a hissing noise and elements keep over heating and tripping the electrics.
Sounds like a broken or slipping belt.
Remove the lid to check belt is in place.
Jan 07, 2009 | Dryers
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
TUMBLE DRYER
Allybo check how the power cord is wired to the dryer. I have seen where the hot wire has been attached to the ground of the dryer and this will create a short which will trip the breaker.
Jan 28, 2008 | Dryers
Dryers Logo
137 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
