Question about Nintendo Wii Console
Power after playing for a few minutes the power switches off and i have to remove plug and plug back in and it starts all over again
Greetings,
Unfortunately, there is nothing you can do on your own. My friend had the same problem with his Wii that he bought at launch. He literally gave Nintendo a call and they offered to replace it under warranty. Nintendo: 1-800-255-3700 They are generally very nice to deal with.
Good Luck,
-WN
Posted on May 10, 2008
My TV takes about 15 minutes to start playing.
It sounds like you have a problem with your signal board. The signal board will need to be replaced.
you can get parts for this tv at www.interliquidparts.com
Feb 22, 2012 | Televison & Video
Error flashing on screen
switch off your stuff and unplug all the power cord so that all setting go back to previous state.
after 10 or 15 minutes plug all the power supply and switch on.
If same happen, notify me again.
Dec 28, 2007 | Philips HTS3450 System
I fell asleep with a DVD playing, when I awoke, the TV screen was as if the DVD has been removed and nothing was in there to read. I checked it, disc was still inside... Powered off for a few minuted. Once...
1: Unplug player. Wait 10 minutes or longer. Make sure disc is clean then Plug back in and try again.
2: Do a factory reset. Should be under settings.
Oct 06, 2017 | Panasonic DVD-S27 DVD Player
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
The on button wont switch on my laptop
Please try following DIY
1.Remove the battery and press the power button for one minute.
2.again plug in the battery and try to start.
3.open the RAM chamber and refix the RAMs.
Jul 14, 2009 | HP Pavilion dv6000t Notebook
Tv powers off after 15-20min
chk fans 4 dust & clean if no help replace the largest visable fan approx 6"
Apr 27, 2009 | Televison & Video
No power
As far as a reset button is concerned you can hold down the power button for a few seconds to turn the power off completely and then power it back up.
If your having power issues and you have a new power adapter thats known working you can try disconnecting the power take out the battery leave for a few seconds then re-insert plug in power and try again.
If this fails try starting just with battery power, if this fails try taking out the battery and attaching just the power adapter and starting up.
Also check that the battery is getting charged there should be a light on the notebook that tells wether its charging.
If this all fails you may have damaged the power adapters connection to the notebook when you bumped it. Hence the battery cannot get recharged to start up.
Let me know how you go.
Mar 23, 2009 | Compaq Presario V4000 Notebook
Start button not working standby light staying
The switch is for 'REC' 'Standby' and "PLAY".
If you leave it switched to "Play" and pull the plug and push it in to the wall receptacle (mains) it should start playing after a few seconds delay. The same for "REC". You use a timer unit on the power cord for those.
If you have the switch in the middle position and plugged-in, you should have a tiny Red LED illuminated. Push "Power" and it should start-up and be ready to use in a matter of a few seconds.
Feb 22, 2009 | Sony MDS-JE520 Mini Disc Player
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
