Question about Brother HL-2040 Laser Printer
How do you change the cartridge? i am having difficulty removing it.
    Scholar:
  • 48 Answers
1. Open the front cover (You'll see two tabs or bends in th eplastic on the sides of the front panel)
2. Pull the handle facing you and you will pull out the toner cartridge and the drum unit.
3. On the drum unit there will be a green or blue tab on the left side that when you press it down will release the toner cartridge.
4. Pull the toner cartridge up and out and insert the new one into the drum unit untill the tab clicks up.
5. Slide the drum unit with the toner back into the printer and close the front cover. The printer should recognize the toner as a new one and you'll be all set!
Hope this helps! Good Luck!
Posted on Sep 01, 2010
  • 526 Answers
you open the front door and pull out the toner cartridge/drum. when you open the door there is a little handle on the left that unrestricts the cartridge from coming out. once its out, you push a button, (there may be 2) on the right side and possibly left, you push them down to separate the toner from the drum
thanks
IM HAVING DIFFICULTY REMOVING THE INK CARTRIDGE FROM MY EPSON LX-300+II, THE RIBBON MUST BE JAMMED ON TO THE PRINT HEAD
first pls remove the power cable after >Open the top plastic lid. > Slide the printer head to the middle of the printer. > Pull the printer cartridge up and out evenly.
Feb 22, 2010 | Epson LX-300 Matrix Printer
Am having difficulty removing Black (96) print cartridge from an HP 7210 All-in-one printer/scanner to enable installation of a new (96) cartridge and need help!
on the software on your PC there was a option in the printer setting>> preferencess>> maintenance, which you can select the ink/cartridge replacement..
Jun 25, 2008 | Office Equipment & Supplies
Tip
How to Replace Canon Cartridges
Printers are just as integral to the office environment as computers.Printers are more compact, more efficient and easier to care for thanever, and Canon printers have always been in the forefront of printinginnovations. Thanks to the diagnostic utilities built in to today'sprinters, we need never be surprised by an empty ink cartridge. When a"Toner Low" or "Replace Cartridge" warning appears, we no longer haveto call the IT department for assistance. Changing your own Canonprinter cartridge is easy and will keep your printer running assmoothly as when it was new.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • New cartridge
  1. Remove the paper in the feeder and put it off to the side while you change the cartridge.
  2. Openthe door concealing the ink cartridge. On most Canon printers, this isfound on the top of the printer and should just lift up and remain openas you change out the cartridge.
  3. Manuallymove the bar covering the cartridge and remove the old cartridge bypulling it back a little and then straight up and out of the printer.It should lift out without any difficulty.
  4. Comparethe new cartridge to the old one and make sure it is the same beforeattempting to install the new cartridge in the printer.
  5. Slide the new cartridge into the empty slot and push it forward. You should feel it click into place.
  6. Closethe top of the printer and put the paper back into the feeder. Print atest page to ensure that the cartridge is installed correctly and thatthe toner is evenly distributed on the page.
on Jan 11, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Replacing Cartridge Valve in Kitchen Faucet
A little WD-40 was all it took, although it was quite difficult to remove using lock wrench pliars.
Sep 14, 2009 | Plumbing
Just changed the cartridge and it only prints part of the page.
You have to go into the printer settings look for paper size, it will probably be on A5 so change it to A4 and it should print properly. (I had the same problem)
May 04, 2009 | Canon PIXMA MP470 All-in-One Printer
Cartridge is jammed
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
Mar 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Having difficulty removing ink cartridges from dell 944 printer
I am very sorry but the Z4M Zebra Printer doesn't use Ink Cartridges, it uses a ribbon to transfer ink via thermal transfer.
Jan 07, 2009 | Zebra Z4M Printer
Epson Stylus CX 6000
Hi-
There is an option on the control panel to change an ink cartridge after pressing menu button, go to maintenance and go to change ink cartridge. if you are having difficulties still, get back to me. thanks for using fixya. pls rate solution if it helps. keep me posted.
Aug 17, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Need help with removing old cartridge so I can replace with new one on my Samsung 2010 printer
Here is a link that tells you how to install your new cartridge. Removal should be the oppisite of the installation.
Hope this helps.
http://downloadcenter.samsung.com/content/EM/200504/20050426164444203/EN/main.html
Jan 19, 2008 | Samsung ML 2010 Laser Printer
Brother HL-2040 Laser Printer Logo
175 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
