Question about Fire Magic Echelon E790I-2A1N Stainless Steel Gas Grill
E790 FIRE MAGIC NOT GETTING HOT ENOUGH - Fire Magic Echelon E790I-2A1N Stainless Steel Gas Grill
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Coil pack is getting hot and no fire is getting to the plugs, plus if i grab the wire that comes off the pack i stiil get a slight shock
I would replace the coil pack, and see if that fixes your issue. You may still get a shock from a bad coil pack, but simply not enough of a punch to fire your plugs!
Sep 13, 2013 | 1991 Toyota Pickup
Not hot enough
Check that the gas jet is not partially blocked limiting the amount of gas out. To up size my bbq to a hotter flame I used oxy welding set tip drills and gently opened up a size. worked a treat and cooked quicker. maybe you can get next size jets for your problem. check that the regulator is not restricting the gas flow.
May 28, 2013 | Fire Magic Grilling
Your Question Preview Fire Magic A790i Logo Problem with A790i Firemagic a790i flames pop and knobs get hot Posted by Author imageGuest on 3/24/2013 Details not getting good pressure to all 3 b
It sounds as if the burners may not be properly seated on the valves. Instead of all of the gas flowing into the burners, some of the gas is escaping behind the front panel and creating a fire behind the front panel which would heat the valve shafts and melt the knob inserts. This call also be caused by partially blocked burner venturi and valve orifices.
Check to make sure the end of each valve is completely inside of each burner.
Mar 24, 2013 | Fire Magic A790i
Kenmore gas dryer not getting hot enough to dry
If inside of drum gets hot suspect first somewhere between it and the place where it vents outside a blockage---Lint can do this and be hard to find and also represents a fire hazard, each year there are hundreds of fires caused by lint buildup that catches fire
Dec 09, 2012 | Dryers
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
Oct 02, 2011 | Magic Chef Ovens
My 1991 eagle talon not getting fire to cranck sensor
i nned to know if your car is a 1.8 engine or 2/0 engine turbo
May 07, 2010 | 1991 Eagle Talon
Monitor only displays blue color, no red or green
hi there, it may be that the RGB balance has been changed. Try getting a person that knows about monitors to calibrate the colors correctly. Or, connect the computer to a different monitor. If it still displays blue, it's a problem for a expert.
Jan 18, 2010 | ViewSonic E790 Monitor
What do i need to hook my fire magic A660 uo to a 100# propane tank?
a regulator , adapter and enough hose or pipe to hook up
Oct 14, 2009 | Fire Magic Grilling
Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Jan 21, 2008 | Magic Chef 31100 Gas Kitchen Range
Fire Magic Echelon E790I-2A1N Stainless Steel Gas Grill Logo
187 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
