Question about Pyle PLR24MPF FM / AM Receiver
I bought a pyle plus plr24mpf radio and I can't install it to my 2004 pontiac grand am. I can get the radio to come on but it won't produce any sound from my speakers. I need step by step instructions
2 Suggested Answers
SOURCE: how do i Install my pyle plr24mpf into a 1993 chevy cavalier?
Here is an easy way to figure it out. Inside the dash where the old radio was, you should be able to find the speaker wires. You should have two that run to each speaker, positive and negative. If you aren't sure about whether this is the correct pair of wires, I've got an easy way for you to find out. Just take a AA (1.5v) battery and touch each wire to one end of the battery just for a second, You'll hear a click come of the appropriate speaker. If you don't hear a click you either have a bad speaker or you have the wrong set of wires.
Once you locate the speaker cables you can just hook them up to the radio. From what I can tell on the internet, this radio is very simple. Red wire goes to the power supply, you will have to find a nearby wire with power from the old radio or you can tap into an existing wire for something else like the cigarette lighter. Just be aware that some wires only have power when the ignition key is on, so keep that in mind, depending on whether you want the radio to go off when you take the key out. Next you should see a black wire, this connects to the body of the vehicle, it is called a chassis ground. Find somewhere metal on the body of the car, and attach it there with a screw and washer. Make sure it is a good solid connection, you don't want it falling off or shorting out. You may see an existing ground wire from the old radio, they are usually black or brown or another dark color. Next you have left channel speaker, and right channel speaker, those should attach to the positive cable of the speaker on the appropriate side. The positive is usually marked with a white stripe or some sort of ridge embossed into the plastic insulation of the speaker wire. The two negative speaker wires will both connect to the chassis ground where you connected the black radio ground wire earlier.
If your wiring setup looks different, or these instructions are unclear, I would recommend you just take the whole works to a car stereo shop and have them put it in for you. If you screw it up you will probably damage or destroy your radio and possibly mess up your car electrical system also.
Good Luck...
Posted on Jan 15, 2010
I have a 2005 pontiac grand prix. I just bought an after market radio. I don't know the what the wires do in the stock wiring harness. i can't figure out which color wire did what function
Well you can start by checking the wires behind the speakers. There are almost certainly 8 of those. Then there is a power wire which ought to be red and a heavier gauge, plus a ground, which should be black.
Or you can just refer to this wiring diagram :>)
2005 Pontiac Grand Prix Car Radio Install Instructions ModifiedLife com
Nov 23, 2016 | 2005 Pontiac Grand Prix
2004 Pontiac Grand Am SE dash back lights quit working I installed an aftermarket radio. Wiring OK no blown fuses.Every thing else works fine plugged factory radio back in lights still did not work.
check that dimmer is turned up ---and check connections around where radio work was done for damaged disconnected line connector also check dash fuses not just fuses from radio --or your radio may not be compatible to your dimmer circuit -most oem radios display are Incorporated with dash functions and after market ones are not
Jul 23, 2015 | 2004 Pontiac Grand Am SE
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
Radio won't work in my 1999 Pontiac Grand Am SE
Check your fuses. I belive the radio fuse is on the passenger side of of dash where it meets the door.
Oct 22, 2012 | 1999 Pontiac Grand Am
Where in the onstar module in a 2004 pontiac grand prix?
On this website (link below) you find fuse box diagram and description for Pontiac Grand Prix 2004
Pontiac Grand Prix mk7 Seventh Generation 2004 fuse box diagram Auto Genius
Nov 16, 2011 | Cars & Trucks
Pontiac grand am 2004 3.4 6cylinder installed brand new battery altenator & starter all good car started took it for test drive everything shut off car wont start. lights radio still come on
Sounds like the security system activated or the ignition is bad. If you have an alarm installed remove it. If you don't then replace the ignition switch after checking all fuses in the fuse panel. There is one that can blow and will give you this symptom.
Jul 22, 2011 | 2004 Pontiac Grand Am
How do I unlock my radio for my 1999 Pontiac Grand Am?
The radio will have to be removed from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or engraved in the metal casing.
May 21, 2010 | 1999 Pontiac Grand Am GT
How do i Install my pyle plr24mpf into a 1993 chevy cavalier?
Good Luck...
Aug 10, 2009 | Pyle PLR24MPF FM / AM Receiver
Pyle PLR24MPF FM / AM Receiver Logo
145 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
