Question about Refrigerators
I am getting mold some where within my portable ice maker. We do not let water sit in it. When we are not using it we totally drain the whole unit and dry it out. I think it is contained within the rubber hoses. How do I clean them out without taking apart the whole ice maker?
  • 828 Answers
A sanitizing solution made with 1 ounce of bleach and a gallon of water will generally kill any mold. Add this solution to the water sump and run the machine in the clean cycle.
Posted on May 10, 2008
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Ice maker has quit working.
It is a simple design. Nothing else in the ice box has anything to do with ice production. The ice maker adds its own water and knows when to harvest with a thermostat built within. All it requires from the ice box is 25f in the freezer or better AND a good water supply valve. Here's how it all goes down: The bi metal thermostat gets down to 25f it powers up a heater to release the the ice and a motor turns the ice out, at very near the end of the cycle 7.5 seconds worth of water is added to the ice mold for future ice production. For the DYIer it is best to start with the water valve because it is cheapest. That might fix the problem. If it don't fix it then yall can use the hundred bucks ya saved by taking the old ice maker down to the home depot and getting another. You will already have a new water valve so a new ice maker completes the deal. Nothing else in the icebox controls ice production. Try this: Add some water to the ice mold manually and wait. If a batch pops out I strongly suspect the water valve is bad. If their is already ice in the mold waiting to be dumped the yall need a new ice maker. The innards have gone haywire.
Jun 14, 2011 | Refrigerators
I just received a Sunpentown model IM 100 from a friend with no instruction manual. I?m not sure where to put in the water in the ice maker. Also there is a plastic male threaded drain on the left side of...
The outside male thread drain should have a cap to hold the water; this is the drain for draining the unit. Filling the unit is as you described, simply lift the lid and add water into the tub. It should not be leaking water from under the unit ... that could be a problem. Good luck!
Dec 05, 2010 | Sunpentown SPT IM-100 Portable Ice Maker,...
Not making ice cubes
Fill ice maker with tap water and let freeze. If ice dumps and water does not refill tray then the water control valve is defective. If ice remains in ice maker then ice maker is the problem.
I think Amana still uses the Whirlpool made ice maker. It consits of a mold, a paddel to remove the ice, a motor to drive the paddel and a cam. The electrical part consists of mold, thermostate or sensor ( use to be thermo-disc), micro switches, 1 to hold the unit running 2nd to alow water to flow at a certain time and a mold heater. Sequence of operation: Thermostate senses mold is cold, activates motor to turn paddels and cam. As cam turns it depresses a micro switch to hold motor running. Motor cam and paddel turn, mold heater is also turned on. As mold warms the paddels scoup out the ice. Contunes to turn until a spot on the cam activates another micro switch to allow water in. Motor continues, as cam reaches a spot it releases the micro switch for water andthen the switch holding the motor on and unit shuts off ready to do it again.
Sep 09, 2010 | Amana ARB2257C Bottom Freezer Refrigerator
Leaking water
That might be the drainage from a defrost. The defrost drain must be plugged. Get in there and clear that drain.
It could also be a leaky water valve if you have an ice maker. Or it could be the ice maker filling too much water into the mold. It's only supposed to fill for 7.5 seconds for a total of not over 5 ounces.
Feb 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Ice maker is not making ice and water leaks from bottom.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Ice Maker
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 21, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker quit working
Sep 07, 2009 | Refrigerators
Kenmore side by side refrig has tube with brown water backed up in it. What is the tube for and why is this liquid sitting in it?
Where is the tube? You have a drain hole in the back bottom of the freezer with a tube attached to it which goes down to the drain pan under the unit.
You have water line tubes on the back going to the ice maker and to reservior in fridge and on to the freezer door up to the dispenser.
There is a fill tube in the freezer where the water comes in to fill up the ice mold.
Sep 04, 2009 | Refrigerators
Flimsy black plastic ice cube mold has dropped into ice service. Ice maker still works. Does this require service?
The teflon is starting to peel off the icemaker. You will need to replace the mold or the complete icemaker. Usually this happens when you turn the unit off and leave the water sit in the mold. To prevent this you should turn the water supply off and let the unit run for at least another hour to make sure the water is out of the system and mold.
Jun 26, 2009 | Refrigerators
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
