Question about Polycom >>> SOUNDSTATION PREMIER EX /AVAYA CO-BRANDED (230501900001)
Our Polycomm Premiere Soundstation 550D is flashing red and the display shows Initialization. It does not turn ON or stop showing Initialization. Is there any way to get it to initialize or go back to Green when you turn it on?
2 Suggested Answers
SOURCE: soundstation2 direct connect ex for nortel
try repalcing the adapter if u have another one.this should solve the problem.if it doesnt , the main board needs repair!!
Posted on Feb 09, 2009
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Toshiba E studio 182 power initialization problem
On startup, if the machine shows a wrench-icon, press down "8" and "clear/stop" key simultaneously to show the exact error-codes. A list of detailed error-codes can be found here: http://officeimagingsystems.com/id175.html
Jun 27, 2014 | Toshiba E-Studio 182 Copy Machine
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
My canon eos 550d shows error 80
ERR 80: SHUTTER
DESCRIPTION: This error occurs in the following conditions.
When the CAMERA self-check system detects that the shutter has not been fully charged (ready to shoot).
When the CAMERA self-check system detects that the shutter operation sequence has not been completed correctly.
When the built-in flash cannot be recharged after the E-TTL preflash but before the main exposure.
REMEDIAL MEASURE: Try clearing the error by turning the main power switch OFF and then back ON.
Feb 05, 2013 | Canon EOS 550D Rebel T2i Digital Camera
Rhythm accompaniment does not play. Start button flashes 3 green then 1 red. Began when someone randomly pushed number buttons on the key pad.
Do an initialization (factory reset) by holding the HIGHEST WHITE key down and turning on the power. Hold the key for an extended time until display confirms initialization complete. This will restore unit to factory defaults.
Jul 14, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
initializing the hard disk before replacing it.
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
To initialize the hard disk
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
Polycom >>> SOUNDSTATION PREMIER EX /AVAYA CO-BRANDED (230501900001) Logo
199 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
