Question about Cosco Metal Crib
Parts for model 10t94 crib
I need the plastic piece that the front rail attaches to the right side. Does anyone know where I can get replacement parts.
Forget it. I tired with Cosco and they don't have parts for cribs over 8 years old. robably the best crib ever made - for the want of a small part it goes to the dump.
Posted on May 20, 2008
Does anyone know where i can find the instruction manual for my crib model #343-8420-0018?
Found this :
Can you help with this Cribs Cradles Bassinets question posted on FixYa
  1. Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
  2. Lower the mattress to the lowest setting.
  3. Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
  4. You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
If this doesn't help you can try contacting the store you bought it from.
Apr 11, 2014 | JCPenney All-in-One Nursery Crib
I need the 2 plastic pieces that attach the drop rails
Certain parts are available only by calling Delta Customer Service directly at 1-800-377-3777 EXT 6221 Monday- Friday 9:00a.m.-5:00 p.m EST.
Or I can send you the ones I have just taken off my crib, when I converted it to a toddler bed. If you want me to please email me kristy.mahar@charter.net
Sep 25, 2009 | Baby Gear
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
I have Ellis deluxe 4-in-1 convertable 8676pro and I need parts
Yup! It is 1-800-858-8323 for Ellis Customer service and parts, be sure to have your model number and serial number found on mattress support. : D
Feb 25, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Looking for teething rails for the Bethany James crib.
gud morning..maybe you can put a replacement of the plastic piece that slides or snaps on and covers the entire top of each side rail, you replace it by puting a cloths on it..and make sure that the child is safe.
thank you
Feb 20, 2009 | DaVinci Leonardo Crib
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Delta Luv Dutchess 2 in 1 crib
The front rail(drop rail) has a little plastic piece attached to it that reads "push".  This will be on the bottom.
Sep 01, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Missing parts
You should be able to take those pieces out of the bottom ends of the crib rail bother than that I'm not sure I have been looking for the plastic pieces for the top of the rail that you squeeze together to lower the side and I called the company and they said they don't carry any parts for this crib anymore. I wish we could all get these cribs together and switch pieces that we need to make at least some of these cribs work its pretty bad. Oh well I hope this helps you.
Apr 21, 2008 | Cosco 2 in 1 10-185-WHO Crib
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Childesign Shelby crib replacement parts
You know I just purchased a Childesigns crib from a garage sale thatI thought had everything needed. When I got home, we found it was missing one top plastic rod. Of course nothing will work without that. I found this webpage that sells a VERY similar product. http://www.productsamerica.com/page65.html. It is not exact, but to be able to use the crib, this was a good option for us. Hope this helps.
Sep 06, 2007 | Childesigns Shelby Crib
Cosco Metal Crib Logo
236 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
