Question about RCA Televison & Video
I moved my DVD player and the disc fell inside the player. Is there anyway to get it out? Model DRC233N
  • 4,102 Answers
Hi the only way your going to get this out is by taking the case off the dvd player.
make sure its not plugged in then just take the case off and you should be able to see the cd and you will then be able to pull it out,
dont plug it in whilst you have the case off
leave it alone if you are unsure and ask someone who has some idea of what they are doing.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 01, 2010
Testimonial: "Thanks for helping me out. I didn't have a clue what to do but I did it. Was very helpful information."
I have a polaroid flatscreen tv with a built in dvd player and i think it fell and everything works except it wont eject anything and it wont let me insert any cds because it has something in it??
look for a small hole it the dvd drawer face.most cd and dvd trays have one. if you see one, use a paperclip/stiff wire to push in and release the door latch. if there was a disc inside, it may have shifted out of place and be blocking the tray from moving.
Jun 14, 2013 | Televison & Video
Door won't open to insert dvd
The gears are jammed, the timing gear is out of sync, or a broken loading belt, or cogwheel.
Apr 19, 2012 | RCA DRC233N DVD Player
I fell asleep with a DVD playing, when I awoke, the TV screen was as if the DVD has been removed and nothing was in there to read. I checked it, disc was still inside... Powered off for a few minuted. Once...
1: Unplug player. Wait 10 minutes or longer. Make sure disc is clean then Plug back in and try again.
2: Do a factory reset. Should be under settings.
Oct 06, 2017 | Panasonic DVD-S27 DVD Player
Continues to say no disc when there is defiantly one in there
Maybe the dvd cannot read the disc.or defective optical lens or defective spindle motor.
Jun 29, 2010 | RCA DRC233N DVD Player
Tray keeps moving
Check inside the tray to make sure no obstacles are preventing the tray from opening fully.Also try a good cleaning disc; dust may be inside the unit.Check and make sure that the button on the front of the panel is not jammed or moved slightly, and is using a full range of movement. Push the putton, and see if it moves solidly. Lastly each manufacturer has Firmware upgrades for the controller chip that runs the tray.You can go to the website of the Manufacturer of the unit, and type in the Model number and make sure that your Firmware does not have an update.
Jan 19, 2010 | Televison & Video
Dvd changer won't play
First have look around see if the discs caused any damage to any of the parts. However you need to be a little clearer on what happens when you attempt to play a disc. For instance does it read the disc? If not perhaps some dust got into the lens area and you might need to clean it.
Dec 14, 2009 | Panasonic DVD-F85 Multi-disc DVD Player
I have a portable dvd player and the disc inside the player that spins fell out and is lost. Is there any way to replace this part?
If this unit is under warranty call this number for technical help on how to return the unit for a new one. Service: 1-877-467-4289. If not call this number for help getting a replacement part. Parts: 1-888-237-8289. Hope this helps you with you problem.
Apr 21, 2009 | Insignia IS-PDVD10 Portable DVD Player
RCA DVD RTD 315 with wrong region
You can try this options..hope this helps;
RCA DRA4008 / DRC220N
  1. Turn player on with no disc in the tray
  2. Press MENU, 1, 6, 7, Mute
  3. Press EJECT and exit the menu
RCA DRC105N / DRC198N
  1. Open tray
  2. Press 1, 6, 7, 1, 9 on your remote
  3. Select region code (0 for all regions)
RCA DRC230N / DRC230L / DRC232N / DRC233N
  1. Power on player
  2. Open the tray
  3. Enter 1, 6, 7, 1, 9
  4. OSD shows current region
  5. Enter 0-6 for region setting before screen disappears
    (Enter 0 for region free)
    Display shows new region assignment (displays "ALL" if 0 is selected)
  6. Power off
RCA DRC612N
  1. Turn on the player without any disc inside
  2. Enter the code "321 789 456" before the player menu appears
  3. Select 'all' in the appearing list for regionfree
  4. Turn the player off
RCA DRS7000N
  1. Turn on the player while disc tray is open
  2. Go to the "Options menu"
  3. Press 8, 2, 1, 3, X (replace X with 1-6 or 9 for multi region)
RCA RC5215P / RC5220P / RC5231Z
  1. Enter 738565250001000X, replace X with the desired region or 0 for multi region
  2. Press INFO
RCA RS2030
    Turn the player on with no disc inside
  1. Wait for the menu to load
  2. Press INFO
  3. Press 0, 2, 8, 3, INFO
Apr 20, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
Various LG DVD Player
Some models of PIONEER cd players had radio frequency problems that caused them to work on and off. Are you near any radio or braodcast towers? Poorly shielded power supplies cause this as well. A weak laser diode in the pick-up assembly in model runs could be the problem. You might want to Google the model number and see if this is common for these units.
Apr 27, 2007 | LG DK 9411P DVD Player
Televison & Video Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
