Question about Canon SELPHY CP730 Thermal Photo Printer
Images are not displayed on the printer's ( selphy cp 730 ) monitor screen -- this includes connection of the printer using a memory card , connection of the printer direct to the camera and connection of the printer to my computer -- in no case will the printer show any images on it's screen.
SOURCE: I'm trying to print from
Fixed the problem by uninstalling all instances of the printer and re-installing printer driver.
Posted on Jun 30, 2008
  • 3 Answers
SOURCE: Selphy 510 won't print from computer, print ok from camera ...
Did you download and install the proper Vista driver from Canon's website? If not, I would suggest that. If you have, then try opening the device manager and look for the printer. Reinstall the driver and just direct it to look in the proper folder for it.
Posted on Aug 12, 2009
SOURCE: Canon Selphy C510 connected and has driver but
copy all the files to the computer then unplug your camera. It will print your files from the computer. Dont forget to check your printing settings.
Posted on May 02, 2010
graemevm
  • 519 Answers
SOURCE: canon selphy cp780 when i
Are you able to upload the photos to your PC?
If so, transfer them to your PC then format the memory card using your camera or PC, then download the photos back to the memory stick & insert once more into your printer.
Let me know if this procedure resolves the issue.
Best wishes,
Graeme.
Posted on Mar 12, 2011
SOURCE: Question Mark Appearing on Canon Selphy printer screen
I encountered this issue with a Selphy CP800 and I presume the reason is the same; it seems to be a common problem. Canon tech support says that Selphy printers need exif data "just so" in order to generate screen previews. If all you do is copy your image to a flash memory device from your camera card, you may well be OK. But if you edit the images (e.g. in Photoshop) you will very likely alter the exif data so that Selphy cannot generate previews from flash media plugged into Selphy. If you are copying images back to a **camera** SD card you may also have to make sure that you don't alter the file structure already present on the card. There are undoubtedly other ways to louse up the exif data of an image so that you can't get a screen preview. Workarounds: 1) official Canon advice is to print the image directly from your computer - that's what tech support told me; 2) if you own Canon's Digital Photo Professional Software you can rebuild the exif data by using File>Convert and save>kind of file = exif-jpeg - this worked for me; 3) Graphic Converter for Mac now has a way of rebuilding exif data according to a poster on the Apple discussion boards; I could not test this out b/c my (old) version of Graphic Converter, 5.4, does not have this capability; 4) if you get a screen question mark, the image will still print - you just can't see the preview. This is only a problem if there's more than one image that generates a question mark on your flash media device because you can't see what image you're printing. So if all else fails and you have to print from flash media, you can put a single image with screwy exif data on a flash drive and be confident that you know what you're printing.
Posted on Mar 28, 2012
Only half of the picture prints on my selphy cp 730 canon printer
Nov 01, 2014 | Canon SELPHY CP730 Thermal Photo Printer
I can't get my iPhone for to connect to my canon selphy cp-800
Canon dont actually specify that this unit can be used on the iphone. it is a photo printer but only works with compatible camers or usb memorysicks, or cards. Im sorry but I dont think that the support for Bluetooth printing or usb printing form the iphone was given as an option for this printer
Feb 09, 2011 | Office Equipment & Supplies
All the lights come on when I switch on my HP Pavillion dv9600 but the screen is blank.
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
If a text error message is displayed, see Troubleshooting Error Messages on a Black Screen During Startup or Boot c02076104.jpg
Black Screen with No Error Messages Connect an external monitor c02076105.gif If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance. Disconnect all peripherals and repeat the hard reset Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset , some devices are often overlooked. c02069237.gif Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.B
b52compters@gmail.com
B52computers
Chris Thrash
Jan 10, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
No display on the printer screen when i insert
Check the specifications for the printer. It may not be able to accept the SDHC cards which speak a slightly different language than SD cards and most older devices will not acccept them. Any sd or 1gb or small card will work fine.
Mar 01, 2010 | Cameras
Jul 30, 2009 | Canon SELPHY CP740 InkJet Photo Printer
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
Nikon Coolpix L4
You have internal problems, possibly the ccd . Also there could be internal connections which have become loose.
Needs repair.
Oct 08, 2007 | Nikon COOLPIX L3 Digital Camera
Canon SELPHY  CP730 Thermal Photo Printer Logo
26 people viewed this question
old marine
old marine
