Question about HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor
Compaq 1720 Monitor
I just bought a used Compaq 1720 flatscreen monitor, and the plug won't interface with my Compaq EVO W4000 tower. Any suggestions?
    Guru:
  • 859 Answers
You may need an adapter plug. They come with new monitors so ask around to see if anyone has one you can borrow.
Posted on May 11, 2008
How to connect external monitor compaq evo n1020v
Plug the cable VGA in to the compac and the laptop. than go to graphic properties and activate your extended desktop. You can also use the monitor as a second one, or clone
Jan 29, 2013 | Compaq Evo N1020V PC Notebook
It's getting power but do not display anything on the monitor
1st unplugging your monitor cable what u see pls reply
Jul 31, 2012 | HP Compaq Evo w4000 PC Desktop
I NEED TO HELP WIRING MY COMPAQ HOME COMPUTER
Set all items up ready to be installed Plug in your mouse and keyboard into the back of the tower. If u are using the old style connectors these have pins and will also be colour coordinated so you know where to plug into tower. They will have a notch inside so plug in carefully so not to break pins. If they are USB connections they will be square at the end and u will see where these plug in at the back of the tower these do not have colour coordination as u can plug in anywhere. Next your VGA cable, this is the cable that looks the same both ends with 15 pins in it. One end goes into your monitor and the other into the back of the tower these are shaped so they only fit in one way, again caution that you do not force in as you could bend the pins. Next ensure u have the power leads into the tower and the monitor, these are the cables with a plug on one end and a female 3 hole socket at the other, u will see where these plug into both devices. Next plug into wall ensuring socket is off first Then switch on Switch on your tower....monitor should come on by itself, if not hit the power button on your monitor Voila ...done
Oct 27, 2011 | HP Compaq Evo D310 PC Desktop
My computer boot very well but without displaying on the screen
try installing the OS again. it should work for you well. And if still you have the same problem, then install the LCD monitor software if you have a LCD monitor.
Thanks for rating good luck
Feb 05, 2011 | HP Compaq Evo w4000 PC Desktop
Is the power supply unit of compaq Evo W4000 could be replace by other brands?
This power supply is quote HP, "250 W Power Supply (PFC)". Almost any power supply will provide that much power. The problem is in a mini tower, the shape has to be matched and that limits you generally to the manufactures PS. Here is one that will replace yours. http://www.codemicro.com/store/product/243891002/New
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 02, 2010 | HP Compaq Evo w4000 PC Desktop
The power supply unit of my pc (compaq Evo W4000) crash... i ask if the power supply can be change by other brands
This power supply is quote HP, "250 W Power Supply (PFC)". Almost any power supply will provide that much power. The problem is in a mini tower, the shape has to be matched and that limits you generally to the manufactures PS. Here is one that will replace yours.http://www.codemicro.com/store/product/243891002/New
Jim
Compaq 1720 monitor: the green light on the power supply went away, the voltage converter was very hot and the monitor went blank
You need to find out if the power supply is still putting out 12vdc, you may have to test it with a load (use 12v car bulb such as the brake lamp). It is getting hot can be due to bad power supply or too much load because of short circuits in the monitor. Please post back what you find about the power supply first.
http://www.unitedsale.com/AC-adapter-Power-Cord-Charger-12V-35A-For-Compaq-1720-LCD-Monitor-Brand-New_p_219.html
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 03, 2010 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
I have faced a problem on Compaq Evo W4000 that there is an error i.e 1801 microcode patch error so how i can remove that error
Give a try to update BIOS. Click here and follow the intrsuction
  1. Obtain a formatted 1.44-MB diskette and place it in your A: drive.
  2. Download the SoftPaq to a directory on your hard drive. The file that is downloaded is an executable with a filename based on the SoftPaq Number above.
  3. From that drive and directory, execute the downloaded file and follow the on-screen instructions to build the ROMPaq diskette.
  4. Place the newly created diskette in the A: drive of the computer to be upgraded or restored and cycle system power to boot from the ROMPaq diskette.
  5. Follow the on-screen instructions to select the Compaq System ROM and flash the firmware. WARNING: DO NOT TURN OFF POWER OR ATTEMPT TO REBOOT THE COMPUTER DURING THE UPGRADE PROCESS!!!
May 10, 2010 | HP Compaq Evo w4000 PC Desktop
Compaq EVO W4000 257951-002 motherboard
Under the cover that you lift off to see the motherboard. Otherwise, go to HP.com and type your model in - you can get all the documentation from them, for free.
Jul 26, 2009 | HP Compaq Evo w4000 PC Desktop
HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor Logo
368 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
