Question about Bosch SHU9950 Dishwasher
Hi, It runs and will not complete. Just keeps washing? Bernie
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
**What I`m about to share applies to All B/S/H/ dishwashers. That includes Bosch, Thermador, Gaggenau and Siemens.**
Based on your description I know what the problem is, though you may not like it. I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line. Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher.
That is just a suggestion out of courtesy however...
If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to.
The reason your dishwasher never completes a cycle is the control has detected a heating error. Here`s the most likely reason why it has detected the error...
Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry.
The issue with your dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless you "stop" it or by pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit runs on and on ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries.
Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Posted on Sep 01, 2010
Jane sanders ***** investigations
U.S. Is Investigating Jane Sanders Over Burlington College Bank Loan ...
https://www.nytimes.com/.../jane-sanders-vermont-burlington-college-investigation.html
7 days ago - Federal authorities are investigating a 2010 land deal for a Vermont college that was run at the time by Jane Sanders, the wife of Senator ...
Jane Sanders Lawyers Up - POLITICO Magazine
www.politico.com/.../bernie-sanders-jane-sanders-lawyer-bank-*****-investigation-bu... Jun 22, 2017 - The strange story behind the federal investigation that has rattled Burlington, Vermont, and put Bernie and Jane Sanders on the defensive.
Jane Sanders Bank ***** Investigation: 5 Fast Facts You Need to Know
heavy.com/.../jane-sanders-bank-*****-investigation-fbi-burlington-college-brett-segl... Jun 26, 2017 - Jane Sanders, Bernie's wife, has hired a lawyer to deal with a federal investigation for bank ***** stemming from a loan she sought as ...
Bernie Sanders says reported investigation into his wife stems from ...
www.cnn.com/2017/06/27/politics/bernie-sanders-jane-sanders.../index.html Jun 28, 2017 - Bernie Sanders on Tuesday defended his wife, Jane Sanders, amid reports of a potential federal investigation related to her time helming the ...
Jul 17, 2017 | Miscellaneous
Hard starting, misfire & cut out when revved with MAP sensor connected
Hi Bernie, Im AL the owner of Big As Auto Repair
Bernie, this is hard to say without diagnosis, but I can tell you that 99% of the time when you unplug the MAP Sensor and it runs better, then its usually the MAP Sensor. If it should turn out that a new MAP doesn't fix it, then check for broken or frayed wires and check the connector for damage. Hope this helps and please visit my auto-repair website and check out my satisfied customer testimonials.
Jul 03, 2015 | Cars & Trucks
How do I respond to someone asking me a question after I've posted an answer for them on fixya? The site seems not to have that capability.
Hi Bernie,
You can always add a comment to the answer you have received.
Under each answer you have received there is a link: "comment". click this link and you will be able to keep corresponding with the expert.
The expert will be notified via email of the additional information.
Nov 14, 2014 | FixYa Service
Kenmore elite ultra wash 4-5 years old. Only a portion of our dishes are getting clean -- it seems like not all the jets are working for the top load. This happens even when there are just a few dishes on...
Solution> Please on the sprayer spindles there are little holes that will buildup a soap substance around it. Take a wire and clean them or run vinegar through it on a regular watcher run and that will improve it but not all together fix it.
Bernie
Oct 14, 2010 | Dishwashers
Spore iPod Touch can't get past level 3
you can use cheats to that or game is made so or it is a trial version
Jan 26, 2009 | EA Sports Spore Creature Creator for...
1994 Tercel Clutch ignition switch
the switch is located next to the peddle, what you can do is to connect the cables and eliminate the switch.
Jun 13, 2008 | 1994 Toyota Tercel
Bosch Maxx WFL 2000: Conditioner Water not filling.
take out the tray. In the roof of the powder tray there is a thin strip of plastic that runs over the conditioner tray, it has 4 square holes in it, if you look closely it is secured by clips. prize them apart to flip down the piece with the 4 holes in it. you will find that it is all blocked up with black gunk, clean it out with whatever is suitable ( i used an hair grip). put things back and check it by putting the washer on a rinse, after a min it will flush out more gunk and things should work fine
May 20, 2008 | Washing Machines
Bosch SHU9950 Dishwasher Logo
97 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
