Question about Eureka 2971AV EZ Kleen Bagless Upright Vacuum
Low suction on Eureka spinduster vacuum cleaner
I just purchased a used Eureka Spinduster vacuum model 2981. The suction on the wand attachment is very good, but the vacuum itself has pretty poor suction. I can see the power brush spinning until I lower the vacuum cleaner, and then it just kind of twirls. I've tried changing the height, but it still isn't spinning well. Do you have any suggestions?
Thanks,
Becky
    President:
  • 1,673 Answers
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
Posted on May 15, 2008
Why when I Pull out handle to use edging attachment, suction stops?
Make sure that the vacuum cleaner is in the fully upright position as there is a slide 'gate' thet directs suction to either the vacuum head or to the handle section depending as to which section you wish to use. In the upright position, you shoud be able to hear the vacuum at the handle where the attachments connect. If you still have vacuum at floor level, check the action of this gate. The actuating mechanism may be broken. Cheers Bob
Jul 12, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
The powerhead cuts in and out on power as you vacuum with the brushes. Works ok with suction only. Have replaced both wands and still cuts out, Can it be the powerhead connections? Help? TJZ
had the same problem with mine check all the prongs on the 2 wands and on the power nozzle and on the handle itself you will probably see that one of them is discolored or burned looking you will need to replace that section, I had to replace one of my wands, and then a second time I had to replace the hose section with the handle attached.
Oct 04, 2009 | Eureka 6984A Bagged Canister Vacuum
Need replacement parts and can't find them
go to geyser vacuum center.com he has hard to find parts .i'm sure he can help you
Apr 07, 2009 | Eureka 6983 Bagged Canister Vacuum
No suction from base or hose attachment
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
Mar 19, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka 2971AV EZ Kleen Bagless Upright Vacuum Logo
489 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
