Question about Whirlpool Washing Machines
Whirlpool LBR6133D. will not let any cold water in. Checked line and is fine...stopping at inlet valve...
  • 176 Answers
Change the valve ithenk dosn't work
Posted on Sep 01, 2010
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Whirlpool 1000 w100 stops after filling with water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 30, 2012 | Creda W100FW Front Load Washer
Whirlpool frontload WAsher. After I run a load, the clothes come out fine. Several hours later there will be an inch of water in the tub. 10 hours more there are 5 inches of water. I have checked the...
It sounds like the water inlet solenoid valve at the rear of the washer where the hose hooks up is leaking, more than likely the cold water valve.
Jan 31, 2012 | Whirlpool Washing Machines
Washer fills with hot water on cold wash or rinse. Turned off the hot water supply during cold cycle and machine stopped filling. Checked that the hoses were connected to right inlet valve and they are.
typically hot is on the left and cold is on the right at the house faucets but in some cases they are reversed so if filling with a cold setting and the right side supply is hot the plumber reversed the lines when the house was built which while its semi rare has been seen numberous times
Sep 26, 2011 | Whirlpool GHW9250M Front Load Washer
Whirlpool Ultimate Care II LSQ9549L top load washer -- hot water okay at inlet on back of unit, but won't fill tub. Is it a valve or a clogged line inside?
Most likey a bad water valve. You can replace it with just a few screws and a pair of pliers for the hose. You can test by swicting around hoses and the plugs on valve if you'd like to test it then try the machine on cold wash(it should be hot). While you switch them inspect the screens for rust and any clogging. Good Luck, Mastatech
Aug 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool AWG338 that has suddenly stopped drawing water. It will run a cycle as if water is there but never actually draws from the main. It has both hot and cold supply.
If water is not getting into the machine, and the hot and cold water faucets are connected, and have good pressure, then parts that can cause the problem are inlet valve, water level switch and timer control.
To start cut power to the applianc3e for five minutes, this can fix a jammed timer control.
If that does not work you may need to call a repairman to test the following:
The inlet valve must be tested by energizing it , testing valve solenoid, and reading voltages to identify a fault in wiring (contact).
If the inlet valve is fine when tested, worth having a look at the water level switch, if it is stuck on overfill position , it will prevent water from getting into the machine.
Lastly,the timer control board should be tested, to ensure that the problem is not a faulty timer keeping the inlet valve on close position.
Mar 30, 2009 | Whirlpool Washing Machines
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Jun 09, 2008 | Whirlpool LSR5132PQ Top Load Washer
Cold Water
Yes, you may have a burned out solenoid(the coil that makes the valve open and close).
If you have a multimeter, you can check for both voltage at the coil and resistance.
Resistance should be anywhere from 60 to 80+ ohms.
Mar 25, 2008 | Whirlpool LSR5102LQ Top Load Washer
Washer won't let cold water in
my guess would be a bad inlet valve. before replacing the inlet valve, check the screen inside the valve,remove the hose and see if its clogged. then check the screen inside the hose at the water valve side. if both of those are clear go ahead and replace the valve
Oct 07, 2007 | Maytag Performa PAV2200
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
