Question about ViewSonic VE700 17" LCD Monitor
The monitor won't work with my computer. It says the input to the display is analog. I need a VGA adapter. What do you think. It's a ViewSonic VE700 monitor.
    Sergeant:
  • 223 Answers
First I would double check in your big box of computer junk look for one of these. that is if your computer has dvi output. Then you should be able to connect to your VE700 with a standard VGA cable, with the Blue ends.The monitor won't work with - 8ff5302.jpg
Posted on Sep 01, 2010
VGA-HDMI connection fail on Acer projector using adapter
You don't say whether or not the "adapter" is simply a gender-changer, or if it actually converts the digital signal from the HDMI port to an analog one for the VGA port. Some monitors have both analog and digital input capability and can automatically adapt to the the digital signal, even if applied to the VGA (analog) port. Other devices are not so smart and need an actual digital-to-analog converter style adapter.
Jul 06, 2016 | Acer XD1170D Projector
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
2yahoo.co.inhow to attach this to dvi desktop
Does your computer's video-card have a DVI-output socket?
Does your LCD monitor have a DVI-input socket?
If 'yes' to both, then you need a DVI-to-DVI cable.
Does your LCD monitor have a VGA-input socket?
If 'yes' to both, then you need a DVI-to-VGA adapter,
and a VGA-to-VGA cable.
Oct 23, 2010 | ViewSonic VG900b 19" LCD Monitor
I have a Viewsonic Monitor vs11349 and it will not connect with my acer PC...it comes up "no display". The monitor has a DVI that I need to use a VGA adapter. SHouldn't it work?
Did you try the setting on the monitor to use the DVI port instead of VGA port. Should also try it on another PC to narrow down the problem. Try VGA to VGA cable also.
Apr 06, 2010 | ViewSonic VX2245WM LCD Monitor
ViewSonic VG2030wm speakers not working
you are unable to get an image on your ViewSonic monitor, first check that the necessary cables are attached correctly and that the proper drivers are installed. ViewSonic offers drivers for download directly through its website (see Resources).
Some LCD monitors use a VGA input while others take advantage of the newer DVI interface to provide a connection to PCs (some ViewSonic monitors offer both types). When connecting your monitor for the first time, you'll need the right type of cable for both your monitor and computer. In some cases an adapter may be necessary to convert the DVI signal from your monitor to work in a VGA input on your PC.
Check that the VGA or DVI cable is tightly attached to the back of your monitor and to the back of your PC. Use the small thumb screws on the ends of the connectors to keep everything tightened in place, which will prevent the cable from getting loose.
ViewSonic monitors also use a power cable to plug into a power source. If the power light does not comes on, check that the power cable is inserted fully into the back of the monitor and that it is plugged into a working wall outlet or a reliable surge protector.
Mar 06, 2010 | ViewSonic VG2030wm LCD Monitor
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
My viewsonic mo9nitor says analog not digital on
To clarify, you know that analog is referring to the VGA 15 pin video input, and digital is referring to the DVI video input, right? You can't have the digital video unless you use the DVI input, which requires a DVI output from your computer (and a DVI cord of course).
If you already knew this and you mean that it won't switch over to your DVI, then there could be several problems. Most of them being with your DVI signal source (computer). Try booting the PC with ONLY the DVI cord attached between the PC and the monitor. If you have a VGA cord plugged into either, UNPLUG IT FROM BOTH ENDS.
Dec 05, 2009 | ViewSonic Computers & Internet
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
May 01, 2008 | ViewSonic VP191b 19" LCD Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
ViewSonic VE700 17" LCD Monitor Logo
103 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
