Question about Zenith R57W46 57" Rear Projection Television
Replacement Lamp Where can I find a replacement lamp? or what is the product/ID number for the lamp that is used? I just bought this from a friend and I want to have a backup lamp on hand.
  • Spherion May 10, 2008
    Ahhh, ok that helps! I've never had a projection tv before so I know nothing about it...do those picture tubes ever need to be replaced? and also before i end up screwing them up can you play a video game system on them? Thanks for your help!!!
    awesome man thanks a lot for your help!!!
  • Zenith Master
  • 8,617 Answers
Is Your correct model number a zenith R57W46? If it is your set doesnt have a lamp. Its a CRT projection so you have 3 CRT (picture tubes) RED GREEN an BLUE
Posted on May 10, 2008
  • Sonny Berry
    Sonny Berry May 10, 2008
    Yes you can play video games use the inputs but dont put them on pause as that will cause the image to be burned into the tubes. Tubes will burn out but they are readily available but do cost several hundred dollars each new used you can sometimes get a good deal.
  • Sonny Berry
    Youre welcome, have a good evening
The electronic circuit broken, lamp doesn't work
listed under air purifier,send to manufacturer
Jul 01, 2015 | Air Purifiers
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
Jul 29, 2011 | Buick LaCrosse Cars & Trucks
Need replacement switch for zing ear ze-256 switch. Used in a lamp, has off, lo and high positions
I have the same issue. I bought a ZING EAR dimmer but it won't fit in the space allowed by the pole the lamp is made from.
The switch is simple, the positions are: Off/On/Half.
The switch uses a diode to provide half voltage to the lamp. I have two solutions and I'm not sure which I'll use yet. First, I can use the dimmer but I'll have to get a 500K pot with a switch to fit in the hole. I'll attach wires to connect to the PCB of the dimmer. In essence, I'll remote mount the 500K pot.
The second solution is to get a rotary switch like this:
http://cgi.ebay.com/Lamp-parts-3-way-2-circuit-rotary-switch-5-8-TR-302-/380282854100?pt=LH_DefaultDomain_0&hash=item588a9fdad4
and use the diode salvaged from the original lamp switch. In my switch the diode is still good.
I know this sounds awfully complicated, but it's really not.
Randy.
Email me and I can give better details if you like.
westerville5595-now@yahoo.com
Mar 05, 2011 | Vacuums
I have a panasonic DLP TV model PT56LC70 lamp is blown and out of warranty. Dealer will not renew warranty. and manufacturer says bulb discontinued. lamp original part is luxim lifi electrodeless RF lamp (...
Just to be sure, I looked at your Model Number and found a PT-56LCX70.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
The part number that I was able to find was LFS4000PA1EB.
But I would contact Panasonic about this problem, they have an 18 month warranty on the lamp product.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Mar 12, 2010 | Panasonic PT-56LCX70 56" HDTV
Christie Roadster 16k is about ready for a lamp replacement. Should the air filter be changed at the same time? If so, what's the Christie product number of the filter?
yes. it is recomended to replace the filters whenever the lamp is replaced. if you have a 500w lamp, use filter #003-120118-01; 1000w lamp, filter #003-120117-01; 1200w lamp, filter #003-120116-01.
Oct 01, 2009 | Christie Roadster S+16K DLP Projector
Sony KF-50XBR-800Replacement Lamp blew after 1 minute
Although this is rare, the problem is the lamp driver board, commonly called the ballast board. Follow the leads back from the lamp an you will find a smallish rectangular board with one large connector and one small one (besides the two wires going to the lamp). If you feel confident, they can be ordered from a Sony parts distributor such as Vance Baldwin or Union Electronics Distributor for about $115 - $150
www.ued.net
Just search under the parts for "Sony" "ballast" and the model number of your TV. Or just call them at their 1-800 number.
If you dont feel confident, you can have a shop repair it for about $450
Mar 20, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
DLP bulb replacement
most manufactures consider the lamp to be a consumable product so the will give you instructions in the box with the new lamp..basicaly,,you unplug the set..remove the lamp cover door,,remove the old lamp,,install the new lamp,,replace the lamp cover door, plug in the set...some companies want you to reset the lamp timer and that info is in the owner manual..get an original lamp and not a generic one..call the manufacturer with you model number and they will most likely sell you one and ship it to you
Nov 27, 2007 | Televison & Video
Zenith R57W46 57" Rear Projection Television Logo
125 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
