Question about Dakota 2786-6 Wristwatch
Have had my Dakota Watch for a long time. Replaced the battery earlier this year but seems to be losing time in the last week. Any suggestions? Thanks Leon Grant Concord, NH
3 Suggested Answers
  • 4 Answers
SOURCE: watch battery number for dakota watch
This watch requires a size 1620 battery, available at all Dakota Watch Company store locations, and most electronics stores. Dakota Watch Company always recommends taking your watch to one of our store locations or a reputable jeweler to reduce the risk of damaging your watch during a battery change.
We are sorry to read of your trouble with receiving technical support. We will be happy to answer any questions regarding your Dakota watch. Please feel free to contact our Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404. Thank you!
Posted on May 21, 2009
  • 4 Answers
SOURCE: Lose or gain time?
We are sorry to read of the trouble you have experienced with your Dakota watch. The problem you have described is typically a mechanical issue that requires a movement overhaul completed by our repair department. Depending on the details of your purchase (date, place of purchase, receipt, etc) this service may be covered under warranty. To determine how to submit your watch for repair, please visit your nearest Dakota Watch Company store location, or contact our Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404. Thank you!
Prc 200 needing battery replaced every week!!! i
Your watch is draining the charge on the battery. It is possible that you have a bad coil or circuit block that is causing the battery to die. An acceptable battery should last you at least 9 months to a year. You need to send your watch in to the manufacturer to have them fix the motor.
Oct 05, 2013 | Tissot Watches
What kind of battery does the texas instruments model 101 watch use?
I am pretty certain that this watch uses two #386 silver oxide button cells. Alkaline cells would work, too, but they'd burn out more quickly--not that batteries last all that long in this watch, anyway. I'm basing this on the slightly newer (~1976-78) plastic-bodied TI LED watch that I have in front of me that I believe contains the same time keeping module as the original model 101.
It is also possible that the earlier watch would have taken #357 batteries, which are the same diameter as #386 cells but slightly taller. Both battery types were popular in LED watches of the time. However, I would suggest starting with #386 cells, as I destroyed the case back of a plastic TI LED watch many years ago by trying to use #357 batteries instead of the slightly smaller 386s. Both batteries put out the same voltage, so the watch will light up with either. However, the case back won't close if the battery is too tall--and if you force it, you can bend, distort, or shatter (in my case) the all-but-unobtainable case back.
Have fun with this watch! Mine still lights up and keeps good time.
May 28, 2011 | Watches
My Quartz sports watch works, loses time, had three months, .
Sounds like battery is failing. Time to replace it! :-) Sears stores usually have a watch repair counter...or find a reputable watch repair business. (Even if the watch is new...its still possible the battery could be failing because you have no way of knowing when it was originally installed! They typically last about 2-3 years depending on age and condition of watch!)
Jan 09, 2010 | Timex 27191 Wristwatch
My wrist watch is continuously losing time. It is
go to the Timex web site "timex.com".
Scroll down to the bottom of the page and select "manuals/downloads."
Select "Product manuals downloads"
Enter you model number in the search box.
Choose your download from the list.
Jan 05, 2010 | Timex Expedition 40141 Wristwatch
I have a Karlsson wall clock sold by Dwell. The
While there may be a way to modify the clock to take a larger battery, I am sure that the manufacturer is dodging his responsibility for poor performance.
Clocks should run for about year or so on a battery. I suggest you send it back and insist on a replacement because the mechanism is obviously faulty.
Don't take any disclaimers from the supplier, it is plainly not "of merchantable quality" and should be replaced free of charge.
Jan 05, 2010 | Watches
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
Lose or gain time?
Jan 18, 2009 | Dakota 2786-6 Wristwatch
Longines watch problem
Some longines watch has built-in battery gauge. When battery is low, the second hand jumps every four seconds. If you have new battery installed and the problem persists then there is a short circuit somewhere that drinks a lot of battery juice.
Mar 11, 2008 | Longines Watches
Dakota 2786-6 Wristwatch Logo
280 people viewed this question
Top Dakota Watches Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Dakota Watch Expert? Answer questions, earn points and help others
