My mp3 player Pro-Sound MV-72 when connected to my PC gets the cartel Loading and there is no more, it is as if you were blocked or something, could help me fix my Mp3.
kjanx
  • 194 Answers
SOURCE: Samsung MP3 Player YP-Z5F
is there a reset button [pinhole] on the player??
should fix it
Posted on Feb 02, 2008
SOURCE: Rio Nitrus MP3 Player
Ok Rio nitrus is great litle thing, and I had the same problem. This is what you should do:
1) download latest firmware for rio nitrus http://www.rioaudio.com/support/rio/downloads/Nitrus/RioNitrus_firmware_123.exe
2) unpack firmware
3) connect Rio Nitrus to your comp;
4)While holding menu buton press power button, you sholud see on display showing UPGRADER text;
5) Then upgrade the firmware ( note that this will erase all the songs- read the read me file that come with firmware);
Although I allready have the same version of firmware v.123 like the one that upgreded this solved the problemm.
Posted on Apr 17, 2008
  • 62 Answers
SOURCE: CAN'T VIEW MY FILES AND FOLDERS ?
It may be just the USB working mode of the player. The USB mode has to be set to either mass storage to view file/folders in Windows Explorer, or the other mode for Syncing with special mp3 player software such as Rapsody. NormalIy the USB mode is "automatic", but sometime this doesn't work or gets set off of automatic. So try setting the USB mode in the player's options. Is that doesn't work, please advise.
Posted on Jul 04, 2008
SOURCE: mosmp078 ministry of sound mp3 player
when i turn on my Ministry Of Sound mp3 player it showing ***Locked*** . i need help
Posted on Oct 29, 2008
  • 16 Answers
SOURCE: i put my personal cd in harddrive and rip, sync to
i load mine by either downloading the song or copy it from cd to computer, instead of trying to sync it to the mp3 player. i pull the folder up with my music and right click the songs i want and send them to the port my player is hooked up to . then i delete the songs on the computer once i remove the player, works for me ,,,,rate
Posted on Aug 16, 2009
Testimonial: "quick responce, honest, punctual info , i will use it again"
My PC no recognizate buslink inUSB and how can i recording music from my PC ,need other sowtware or something else ?
As far as I know you cannot record music from your PC. You can however use recording software (like windows sound recorder) to record wave files (WMA) and upload these to your mp3 player. Most players have onboard converters to convert to mp3 whilst uploading. Or you can download mp3 files form the internet and upload to your player. If your player is not appearing in "My Computer" when connected to the USB port, you have a different set of problems which could require you to fromat the player to FAT32.
Apr 13, 2010 | BUSlink (MP3-NBD256) 256 MB MP3 Player
I get no sound when connected to CD connection
if there is no phono input,you need a pre amp to drive it.the record player puts out 5 mv from the cartridge.
a cd player is 800 mv to one volt output.
the turntable can not drive the cd input.
a phono pre amp also has a 60db gain from 20hz to 1khz to offset the -60 db curve when records are made to reduce the groove modulation.
without the bass attenuation,record grooves would have to swing 4" for bass notes.
google RIAA equalization curve for a description.
Sep 01, 2009 | Yamaha HTR-5830 Receiver
When I turned on my sandisk I pushed something and now there is no sound. In the "window" there is a little solid block that I can't figure out how to get it off. HELP!
all you have you do is go to your computer and put da USB cord and whene something comes up.........poop!!!!!!!!!!!!!!!!!!hahahahahahahahahahahahaha
Jan 30, 2009 | SanDisk Sansa Clip MP3 Player
Windows XP Pro will not recognize Coby MP3 player.
could be one of two possibilities. one something is wrong the usb wire or two, the player is locked. mine did the same thing when i first got it. i unlocked it and it worked
Jan 05, 2009 | Coby MPC-683 MP3 Player
Can't get installed
Windows XP Pro is very nasty when it comes to reading mp3 players. The OS is designed for maximum secuirty, so unless you change the security settings, it treats the mp3 player as an "unauthorized user". Here is some general TS to try first:
RCA M4208
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
-Tha Mp3 Doctor
Dec 26, 2008 | RCA M4208 MP3 Player
8gb mp3/mp4 player
If your iPod is frozen or won't turn on, your iPod may be paused or on "hold." Slide the Hold switch and check the screen.
If your iPod is frozen or won't turn on, connect your iPod to your computer, then press and hold the "Menu" and "Select" buttons simultaneously for 10 seconds to reset the iPod. Resetting an iPod will not affect your files or preferences.
If your iPod fails to hold a charge and it's more than a year old, you may need a new battery.
If all else fails, file a complaint with ebay stating you were sold something that was not properly described - unless the seller made it clear there were issues with the unit.
Hope this helps some!
TWEAK A/V LAB
Oct 26, 2007 | Apple iPod nano
What should i do?
Connect it to your USB port and try a Firmware re-load. There should be a disc and instructions supplied with your player. Things like unplugging the player during loading, battery failing etc, can cause a Firmware crash that can often only be resolved by re-loading.
Aug 29, 2007 | Mach Speed Trio DA-8033 MP3 Player
Stuck while loading music??
The same thing happened to mine a couple of times.. I let the battery run completely down then plugged it into my computer.. after a couple of attempts it seems to recognised the mp3 player, and works at least for a bit after that. I've now deleted and added quite a few various tracks, and it has been fine for a while now.. so not sure if it might be a corrupt/dodgy file taht I've now deleted or something?
Jan 28, 2007 | Sony NW-A1000 MP3 Player
Same problem with MP3
try to connect it other computer,if it works normal on other pc then its ok, or you can also try to use other usb port in your pc, and if this doesnt solve your problem, i think you should replace it.
Jul 30, 2006 | Creative Labs MuVo V200 MP3 Player
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
