Question about Compaq Keyboard
Keyboard model 51351 Key functions are transposed.
Keyboard model 51351 Key functions are transposed. Enter the @ key and it brings up " Enter the " key or the £ key and it brings up the @ sign
2 Suggested Answers
  • 8 Answers
SOURCE: Messed Keys
Try reinstalling the driver for the keyboard. If that doesn't work try the keyboard on another computer. If the same thing happens you probably have a faulty keyboard and will need to replace it. If not, check for a more updated version of the driver at the manufacturers website.
Posted on Dec 31, 2008
My Ketron Sd5 seems to play a different key on the right than on the left. For example if I play a beat in the key of G (left) the right hand side plays in A. Can you help?
You need to check your manual for instructions on key transpose. The right side has been transposed one key higher. If you don't have the manual, try resetting the instrument by removing the internal battery and reinstalling it. Good luck!
Aug 01, 2016 | Ketron SD5-61-Key Arranger Workstation...
Is there a way to program the whole keyboard to play 1 octave lower?
You can use TRANSPOSE/SETTING button.
Each press the TRANSPOSE/SETTING button cycles through the setting screens. If you accidentally pass the screen you want to use,keep pressing the TRANSPOSE/SETTING button untill the screen appears again.
To lower by one octave,set the value to -12
You also can use PIANO SETTING button.
Find the setting in page 07 of PIANO SETTING.
Sep 03, 2015 | Casio CTK810 61 Key Keyboard
How to reset factory defaults for a Casio WK-8000 keyboard
1. Press the Transpose/Function button
2. Cursor down 3 times to "Init Mix"
3. Cursor right to "Init Sys"
4. Press Yes twice
5. When it says "Please Wait", don't press any keys
6. After that, press Exit once and it's ready to go
http://www.sweetwater.com/sweetcare/articles/reset-casio-wk3000-factory-defaults-hard-reset
Please rate my answer, Thank you.
Aug 05, 2014 | Casio KEYBOARD WK-8000
Why did my enter key suddenly no longer function as to enter, when pressed it brings up a toolbar instead of taking to the next line?
your keyboard utilizes keys F1-F10 as re-programmable function keys.to change your current pofile press the razer lycosa logo+functon key(f1-f10) or you can reset your keyboard to factory default settings by pressing the "Razer Logo" button for 15 seconds while the Razer Lycosa is connected to a powered on computer. NB: ALL CONFIGURATION SETTINGS WILL BE LOST WHEN YOU RESET THE RAZER LYCOSA
TO FACTORY DEFAULT SETTINGS. ALL CONFIGURATION SETTINGS WILL NEED TO BE
RE-ENTERED OR LOADED FROM THE CONTROL PANEL AFTER THE RAZER LYCOSA IS RESET.
Jul 21, 2013 | Razer Lycosa Gaming Keyboard
Acer laptop enter key dosnot function
Bring it in to a repair shop and have them replace the keyboard. It should be relatively inexpensive.
Jun 29, 2012 | Acer Computers & Internet
I have a Roland E-70 Intelligent Synthesizer, buit the manual does not give instructions on how do transposition. I need to transpose the instrument to play a music in a lower key. For example, when I...
section 7 page 89 of the E-70 manual I downloaded from http://www.rolandus.com/support/owners_manuals/?group=2
describes the use of the transpose button.
In short, you set the value for the transpose function in the parameter menu (section 9 in the manual) ranging from -11 to +11 semitones.
In your case I would set the value for the tranpose button in the menu to minus 2 as you want a full note (= 2 semitones) down from C to B-flat and G to F etc.
And you activate or deactivate the transpose function itself by hitting the transpose button. The little red led next to the button shows whether the function is on (led is lit) or off (led is not lit).
Hope this helps
Mar 12, 2012 | Music
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
Software problem, my keyboard prs s500 have lost it key arrangement order ,where by now key f is found in key g, .please help me how to restore its arrangement
Look in your manual under "transpose". The transpose feature shifts the keys up or down often up to a full octave. This allows you to play in ANY music "key" you know and generate sound in a different one for say a vocalist who only sings in another...
Mar 25, 2011 | Yamaha Music
How can I find out what all the F1, F2, F3, etc. keys on the keyboard do?
The link below will tell you what all the keys on the key board will do.
http://www.internet4classrooms.com/winkeyboard.htm
Good Luck and please rate 4 thumbs up for the free answer
Oct 01, 2010 | Computers & Internet
Transpose feature on the Roland RD-600 digital piano
If you want to play in C and carry the sound of Bb,
1. From C, count down two half-steps to Bb
2. Press and hold the Transpose button and press the key on the keyboard that displays through the window, "-2"
3. To turn off the transpose feature, just press the Transpose button again.
Feb 23, 2009 | Roland Vs-2000CD Digital Studio...
Compaq Keyboard Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
