Question about Dryers
Want to change dryer belt - Dryers
  • Stu47 May 10, 2008
    I live in Brazil so repair parts are not easy to find. The problem is this. Everything appears to work but the drum doesn't turn. If it is the belt, how do I get to it. If not, what may it be? Stu47
  • 117 Answers
Im a brazilian too
what brand is your dryer and model number
Posted on May 10, 2008
When dryer turned on a humming sound is heard, but the dryer does not start(drum does not tumble)
Links on how to change dryer drum belt below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Belt Replacement
How to Change Clothes Dryer Belt
How to Replace Dryer Drive Belt Repair Guide Help Sears PartsDirect
Feb 26, 2016 | LG Tromm Electric Dryer
Tip
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/1246110?modelNumber=LDE8424ACE#repairHelpVideoTabs
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
How to change the belt on a whirlpool AWZ7814 AL
These dryers have common roots with lots of other brands. You should be able to see what you need via either video:
How to Change Dryer Belt on Whirlpool Dryer or in Instructables
How To Replace Dryer Belt on Whirlpool Models
Nov 18, 2015 | Whirlpool Dryers
Change dryer belt
Good Morning Friend,
I understand you are trying to change the dryer belt on your Frigidaire dryer, model# MEX731CFS4. Typically, this is not a do it yourself repair, as there are no step by step manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to change the dryer belt with ease. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire Washing Machines
Changing belt on my dryer
I am not familiar with this particular dryer, but all electric dryers are designed so that the consumer can replace the belt. Open the access door ( the back, the top, or the removable panel at the bottom front) and the belt should be visible; a few minutes of study will show you what you need to do to change it.
Apr 22, 2009 | Candy CDV262 Dryer
Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
Mar 26, 2009 | Dryers
Changing dryer belts. How do I open the dryer to change the belts? I think one of them are broken.
either the top pries up or you'll have 2 screws at the very bottom of the front panel from there you can remove the front panel but make sure you disconnect the door switch wires before yanking the front panel away
Mar 11, 2009 | Kenmore Elite HE4 Electric Dryer
Fan Belt replacement
most dryer to chang the belt is take the top and the front cover off and the drum out . you will see the belt. but if you give me the m# of the dryer i can help moor.
Dec 28, 2007 | Dryers
MAYTAG DRYER LDE4914ACE BELT CHANGE
The belt goes around the pully so that the pully tension takes the slack out of the belt. Just like the serpentine belt on your car.
Nov 15, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
423 people viewed this question
Top Dryers Experts
