Question about Maytag MDG308DAWW Gas Dryer
I have a model MDG308DAWW gas dryer which is experiancing No heat issues. the burner will fire up occasionally when we first load it and then will not come on for the rest of the dry cycle, I have cleaned the lint passage ways and am wondering if the thermostat may be bad or could it be a limit switch. and if it is the thermostat where is it located in my dryer?
  • Maytag Master
  • 3,051 Answers
Hello there:
If your dryer doesn't heat, check these:
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Sep 01, 2010
Maytag model mdg308daww
What is the problem you are having?
May 22, 2012 | Maytag MDG308DAWW Gas Dryer
My mdg308daww spins, the heat igniter, glows for about 5-10 seconds and then stops after about a minute it glows again. The igniter was tested ok, and the coils were replaced still the same problem....
Assuming the gas supply valve is turned on, I would make sure the gas valve orifice in your dryer isn't plugged up. If its not that leaves your gas valve not letting the gas in. Very rare though.
Sep 25, 2011 | Maytag MDG308DAWW Gas Dryer
My maytag model- MGD5740TQ0 gas dryer burner fires only for 10 seconds and stops; repeats every 2 minutes or so buy does not stay on long enough to dry load
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 22, 2010 | Maytag Dryers
MAYTAG DRYER MODEL MDG308DAWW IS NOT HEATING
heatman101
Oct 17, 2010 | Maytag MDG308DAWW Gas Dryer
MAYTAG gas dryer won't heat
heatman101
Sep 16, 2010 | Maytag MDG308DAWW Gas Dryer
Maytag 2007 model mdg308daww quit working
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 30, 2010 | Maytag MDG308DAWW Gas Dryer
I have a Maytag gas dryer, model MDG308DAWW serial 10578801GP. The dryer will start and heat up but after it runs for a short time the burner goes out. I bypassed the thermo limit and the problem still...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 20, 2010 | Whirlpool GGW9250PL Gas Dryer
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer ignites inconsistantly
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jun 25, 2009 | Maytag MDG308DAWW Gas Dryer
Gas dryer
be sure burner is firing off every time it is supposed to if ignitor glows then shuts off without burner firing replace the coils on burner (2 black round things) if burner ok remove rear vent hose and try load without connected if works ok suspect flattened hose behind dryer or line to outside restricted
Jul 16, 2008 | Whirlpool LGR5636PQ Gas Dryer
Maytag MDG308DAWW Gas Dryer Logo
223 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
