How to unlock the disc tray on my JVC compact component system MX-KB30
Try while playing a disc, Stop button(Beep On/Off) + disc Eject, Hope it works.
Posted on Aug 30, 2008
    Sergeant:
    Champion:
  • 319 Answers
If your CD player dose not respond to normal commands, there is a problem with mechanism. Have serviced
Posted on May 10, 2008
JVC MX-GT88 sound system showing protected them shut off why
Chances are that something is blown in the power output stages and units shuts down to protect against further damage.
Repair or replace, which ever is cheaper!
Dec 08, 2015 | JVC MX-GT88 CD Shelf System
Jvc home component mx-kb30 protect mode on
First check that the speaker wires are not shorting, if okay! the problem is in the audio output stage of the receiver, the protect mode comes on if a load is detected.
Apr 25, 2012 | JVC MX-KB30 300W Mini Home Audio System...
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
Need to set clock on jvc compact component stereo amp
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Oct 21, 2009 | JVC MXKC4 360-Watt Compact Component Audio...
JVC Compact Component System MX-D402T Problem
Hi ryv
The unit may need to be hard reset. Disconnect the unit at the wall and leave unplugged overnight and then try again in the morning, If this does not solve the condition, then it will need some repair work done to it by a JVC Auth service guy.
regards
Graeme
Apr 26, 2008 | Audio Players & Recorders
JVC Stereo won't open cd tray
Maybe something's jamming it, try fixing the drive, so it comes out.
Mar 16, 2008 | JVC MX-KB30 CD Shelf System
Tray will not open!
press &hold stop then press the eject button.
Nov 04, 2007 | JVC MX-KB30 CD Shelf System
JVC MX-KB30
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
Sep 22, 2007 | JVC MX-KB30 CD Shelf System
JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Jan 24, 2006 | JVC MX-KB30 CD Shelf System
155 people viewed this question
 Grubhead
Grubhead
