Question about RCA P61960 61" Rear Projection Television
My rca tv
CANT SEEM TO GET MY TV OUT OFF IT SSHOWING UNUSABLE SIGNAL PLEASE HELP DO ANY WIRES NEED TO BE PLUGED INTO THEBACK OF THE TV PANEL THANK YOU
  • scubbs Jun 08, 2008
    im having the same problem on my RCA P61960 61" i just moved and it might have got bumped a bit not sure but when i try to use my component video hook up i get a blurry distorted picture for a few seconds then i get an unusable signal message if i change my input to just cable it works fine please help
  • Christopher Rivera May 11, 2010
    What are you trying to do?
Im having the same problem on my RCA P61960 61" i just moved and it might have got bumped a bit not sure but when i try to use my component video hook up i get a blurry distorted picture for a few seconds then i get an unusable signal message if i change my input to just cable it works fine please help
Posted on Jun 08, 2008
I time Warner internet and phone line all my 5 computers working but my smart tv works some times and then it loses connection
Is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - Does your wireless connection connect, then disconnect, then connect again, only to disconnect .... I did try 1,6,11 not working it's drop away.
Samsung smart Tv and internet connection ' AVForums
www.avforums.com > Forums > Home Audio Video Forums > Televisions
Feb 23, 2013 - Chaps I have connected my Samsung Tv to the home network but it can be ... Sometime it works great, and then it drops to unusable speeds.
WiFi drops over and over - Comcast Help and Support Forums
Dec 09, 2015 | Televison & Video
My rca tv has unusable signal onit
Hi, Check the cable connections to and from the TV.
Change the channels to see if there are others that are out.
If you are not using any cable company then you will still need a set top box to unscramble the digital signal. Good luck.
Jun 06, 2012 | Televison & Video
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
Unusable signal
video inputs do not have channels you must not have it on the right source. Turn your Wii on then change the input untill you find it.
Sep 08, 2009 | RCA F32648 32" TV
When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Take the back panel off and look for a smd fuse with an F on it. Middle panel in the upper left corner, it is about the size of a tip of a pen. We used a copper wire to make a jumper. Works great now!!! We also noticed that there we some loose pieces and we pushed them back in and now the buttons on the side of the TV work.
May 17, 2009 | RCA L37WD12 37 in. LCD HDTV
"Unusable Signal"
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.ebc3c7f.jpg
Mar 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
I am having a problem with an RCA tv..unusable signal.
make sure that you have it set to the right input signal source and that your source is working properly. if so then yeah, you need to replace the fuzle modulator.
Mar 11, 2009 | RCA L46WD22 Television
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Sep 24, 2008 | RCA 244889 Remote Control
RCA P61960 61" Rear Projection Television Logo
425 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
