What are the symptoms of external power roblems on a computer?
    Brigadier General:
  • 10,406 Answers
The most-common symptom is random "freezing" of your computer, requiring a power-off/power-on sequence to "reset" your computer.
Posted on Sep 01, 2010
At every particular time in the evening, my car temperature rise even when the is blowing. And I have worked on the thermostat. What next should I do
At least you did not indicate cold air which is a thermostat issue and stuck vent door plus failing water pump. Your symptoms are tempters sending switch -check vale or air in the system which the bleeder vale should be bleed to remove air out the system that would elevate the roblem
Feb 21, 2015 | 2003 Honda Odyssey
The blue light keeps flashing on and off on my Seagate 4Tb XHD. It won't show up on the finder as connected. What causes that?
follow these steps:
  1. Make sure the computer and external hard drive are powered on.
  2. Safely remove the drive from the computer (if possible).
  3. Disconnect the external drive's USB or FireWire cable.
  4. Disconnect the power supply plug from the external drive.
  5. Power off the computer.
  6. Disconnect the computer's power supply cord for 60 seconds.
  7. Reconnect the computer.
  8. Power on the computer.
  9. Connect the power supply to the external drive.
  10. Connect the drive's USB or FireWire cable and check for detection.
If that does not correct the behavior, and if the drive is also not detected by your computer, the blinking light is probably a symptom of a larger problem. If those steps do not return the drive to correct function, it is very possible, even probable, that the drive has failed and needs to be replaced
Dec 22, 2014 | Seagate Computers & Internet
How do I make the volume from my speakers louder than my computer speakers?
depending on the auxiliary speakers you have, there needs to be a power source (either batteries, a power supply, or an ac cord); and the power needs to be turned on. Symptom sounds like you don't have the external power connected or turned on.
Dec 16, 2014 | Audio Players & Recorders
The item "IMB_0541.MOV" could not be moved because "TOSHIBA EXT" cannot be modified.
There are several possible causes for this symptom. It's possible that the external hard drive isn't getting enough power. Make sure that it's power adapter is connected correctly and working. If it's powered through USB only, try connecting it to another USB port on your computer (avoid plugging it into USB hubs and using long and thin USB cables).
Unplug the hard drive completely for at least 10 seconds, power off your computer in the mean while, power it on again (not a direct restart) and see if it resolves the issue.
Try to connect the drive to another computer and see if the issue persists. If the drive has the same issue on several computers, there might be a severe problem with the drive. If that's the case, start shopping for a new external drive. There's a chance for simple data retrieval though. If it's the electronics in the enclosure, the actual hard disc drive is probably still fine. If that's the case, you can find a way to open the enclosure (do a Google search with the precise model name and you'll probably find a tutorial) and you can install the hard drive in a desktop computer, a hard-drive docking station or another enclosure. Try to find a computer-savvy cousin/nephew to help you with this.
Dec 15, 2013 | Toshiba 200GB USB 2.0 Portable External...
How to resolve a stuck key roblem?
Hello, The causes of stuck keys is as a result of dust in the laptop keyboard,you have to open the laptop and blow it,with a vacuum blower, if you cannot open the laptop on your own, you can give it to a technician,you can also buy an external keyboard and connect it to your computer, it will work, you can buy that with a USB interface,or if the problem is not dust,you might want to replace the keyboard of your laptop, yes it is replaceable. Regards
Nov 26, 2010 | Sony VAIO VGN-FE880E/H Notebook
When I power up my laptop the screen does not show anything. It is just white screen no windows log or bios when the computer is booting. I can connect an external monitor to the laptop and the see that it...
You've got a loose connection between the laptop and the internal screen. Take the computer to a qualified technician, tell him/her the symptoms, especially the part about the external monitor working fine, and pay the technician to fix it.
Oct 27, 2009 | Acer Aspire 4315 Notebook
Not powering up with steady orange power light
Did any one open the system, after which you are facing this problem?
If the 4 pin power connector is disconnected, you will face the same symptom.
This symptom can also appear if you have any external or internal devices electronically failed / Short circuited. Remove any external devices even external hard drive, flash memory devices, camera, printers etc and then restart the computer.
There is also a possibility of flea power, remove the power cable from the tower and press and hold the power button for 10 seconds, this will drain charge from the capacitors from the motherboard.
then connect the power cable and test if your issue is fixed.
if the issue is still not resolved, then we have to remove any internal devices, eg, add on sound card, video card, modem etc and then try powering up, if the issue persists there could be a problem with either the motherboard or power supply, which needs parts to be replaced and tested.
Jul 24, 2009 | Dell Inspiron 530s Desktop Computer
Maxtor 3100 will not work on Desktop with Windows XP Home version
actually telephone numbers are not available through this service...perhaps you will consider a premium or chat investment of your resources.
Oct 20, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Harmon/kardon computer speakers bought on ebay missing power adaptor
Get the speakers with you walk a distance for your Nearest electrical shop as quickly as possible and your roblems will be solved...
Jan 03, 2008 | Harman Kardon HK206 Computer Speakers
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
