Question about KitchenAid KGST307 Gas Kitchen Range
Sparks that make fire start never stops even after fire is on for awhile even when button is in different angles
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 02, 2010
Will not crank
Tps has nothing to do with sparks. If you had sparks going to the distrubuter but none coming out, the cap or rotor is not installed correctly.
Nov 10, 2017 | 2001 Chevrolet Express
Vehicle turns over but won't start, was running fine when i parked it!
have someone try to start the truck while you watch the distributer cap look for sparks cross fireing between wire ends cheek inside cap for cracks or corroded contacts.
Jan 29, 2013 | 2004 Ford Explorer
Makita ga9020-230 making grinding noise and then starting flicking sparks even after replacing the brushes, please help
It sounds like the armature is shot. When the armature goes bad you will see excess sparking from the brushes.
Jul 04, 2011 | Makita GA9020 Angle Grinder
MY MERCEDES CLK 320 RUNS BUT AFTER AWHILE THE IDLE DROPS AND WHILE IM SITTING AT A RED LIGHT IT CUTS OFF AND WONT START UNTIL 30 TO AN HOUR LATER
start the car, if stop like after half an our to one our, and then after one our again start fine and can drive another 15 minute, again same thing happen and continue the same. is the problem same in your car, faulty crank angle sensor replace crank angle sensor,
Oct 17, 2010 | 2001 Mercedes-Benz CLK-Class
In raining conditions one cylider stops firing and will occassionly kick in for one or two fires intermittantly when dry no problems
Sounds like the spark wires are dried out and cracked and losing the spark to ground. Start the bike in the dark and spray some water on the plug wires, you should see some nice blue sparks jumping around, even without spraying the water maybe.
May 15, 2010 | 2005 Suzuki GS 500 F
My grinder was having a lot of blue light/sparks where the brushes are and now it is not even starting
It either has worn out brushes or switch fault, take it to a power tool specialist for repair.
Feb 17, 2010 | Makita 7" Electronic Angle Grinder -...
Sparks when shooting a nail
It is common to see sparks. It is metal striking metal. Although, if it sparks alot. It could be a chipped driver blade and the nail would not drive all the way. Does your sink `em?
Aug 15, 2009 | Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15...
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Quietsource 25kw Staring problem In auto mode or manual
Sounds like the you have no spark since when you force the engine to crank it never fires. The low battery light come on because the 2 sec of cranking lets the voltage get lower than the alarm threshold.
I'd connect a spark tester to either of the plugs and try a manual start, if you see sparks replace the plugs, if you get no sparks then you've got to troubleshoot the ignition modules and the kill wire that comes from them.
Regards,
Carl
Feb 23, 2009 | Generac Electrical Supplies
KitchenAid KGST307 Gas Kitchen Range Logo
53 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
