Question about Lexmark P4350 All-In-One InkJet Printer
MY PRINTER KEEPS JAMMING THE PAPER AS I TRY TO PRINT SOMETHING. THE PRINTER IS A LEXMARK P4350 ALL IN ONE
  • Lexmark Master
  • 17,130 Answers
First of all check the quality of the paper used, is it of low thickness. if so change with a different type.
If the printing paper is good then the rollers can be moving over with different pressure on the paper making it touch unevenly and so pulling the paper differently.adjust the rollers and if possible tighten so that it touches evenly.
The roller will now move the paper without any side pulling and jamming.
Posted on Sep 01, 2010
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Lexmark 3400 series paper jam
hmmm...well.that suggests that you have something along the left side
open up top and back, and inspect for any paper fragments
Aug 19, 2008 | Lexmark X1270 All-In-One InkJet Printer
Paper keeps jamming
I have the same problem on my Dad's printer. It takes regular paper ok, but will not feed the photo paper.
Dec 28, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
LEXMARK PRINTER DOES NOT WORK JAMS PAPER
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 29, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Jamming paper
The paper pickup rollers might be worn out. They can be restored by rubbing Acetone (use gloves)on them just make sure that the acetone doesn't touch any plastic. There also might be a piece of paper stuck in the printer paper path. It might be out of sight and blocking the paper as it feeds into the printer.
Mar 16, 2007 | Lexmark P4350 All-In-One InkJet Printer
Paper keeps jamming
My husband and I found that if you hold down the red lever to the left of the paper drawer, you can get the unit to print. Something about the paper roller not coming down to pull the paper into the machine is why it keeps jamming. Good luck
Jul 29, 2006 | Lexmark E232 Laser Printer
Lexmark P4350 All-In-One InkJet Printer Logo
277 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
