Question about Creda W100FW Front Load Washer
Door will not open at end of cycle - Creda W100FW Front Load Washer
  • Creda Master
  • 17,129 Answers
Possible that the safety link to the end cycle is not released. So check from the bottom to see the lock settings and check if the release link is stuck or the lock by itself is jammed.
Use a good degreasing spray like WD40 to remove any jamming in the door.Once released use the spray to wash off all dirt or foreign material from the lock setttings. The open and shut a number of times to clear the lock movement.
Posted on Sep 01, 2010
Now whether this questions category that this question is in is the right category or not but my kenwood k30css14 when I close the door after opening the door during the cycle it Dosen't continue
These new ones don't like to be interrupted! have you tried restarting cycle, if so try restarting cycle, with cycle in the on position, turn timer from beginning to end till clicks open door, close, restart cycle. hope this helps. Try unplugging re plug with timer in off position, end cycle first !
Nov 03, 2016 | Washing Machines
Why cat I open door at end of wash cycle
http://www.whitegoodshelp.co.uk/washing-machine-door-will-not-open/
Mar 14, 2016 | Hotpoint Washing Machines
Detergent cake left in dispenser after wash cycle
Has the dispenser door open at end of cycle. If dispenser door is open but not fallen down to the tub means most likely the water arm pressure is not good enough to get flush down to the tub.
Door not open means dispenser failure or control board not giving power to dispenser at right time. In some cases dispenser door is stuck with harden earlier soap so it cannot open completely in the cycle.
Why not when opening the door at end of cycle, listen to dispenser area to see the flapper opening while you are opening the door. That means dispenser not opening properly in the cycle.
This issue is a hard solve sometimes. Don't wont to spend the money, then just use the tablets and through them in the tub in the beginning and say good bye to dispenser.
Apr 06, 2015 | Whirlpool ADG450 Slim-Line Built-in...
How do i program keyless remote on 2004 navigator
1. Close all doors and then open drivers door and press the UNLOCK
button on drivers door panel while door is open and insert key in ignition.
2. Turn ignition from OFF to RUN 8 times within 10 seconds, with the
8th time ending in RUN. Door locks will cycle to confirm programming
mode.
3. Within 20 seconds press any button on first keyless remote.
Door locks will cycle to confirm programming.
4. Within 20 seconds, press any button on second keyless remote.
Door locks will cycle again to confirm programming.
5. Turn ignition to OFF.
Locks will again cycle to indicate end of programming mode.
Oct 13, 2012 | 2004 Lincoln Navigator
Maytag neptune mah3000aww washer. It cycles then sits at the end of spin, does not go off. then the door will not unlock. I turn to off, push off button. it is anyones guess if it opens
Possible that the door lock is not actuated to open after the end of the cycle and could be jammed. try using a degreasing spray like WD 40 and if there is any issue with the lock.
check this link: door lock
Jul 05, 2012 | Maytag Washing Machines
Door wont open on washing machine zwf16581w at the end of the cycle
The door is designed to stay shut at the end of a cycle usually for about 4 minutes, even if you switch the machine off at the mains. Other than that you probably need a repair.
Dec 17, 2011 | Zanussi Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Creda W100FW Front Load Washer Logo
56 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
