Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water valve noise clicking
    Brigadier General:
  • 3,917 Answers
Hi
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Also check this link…
http://www.repairclinic.com/Refrigerator-Troubleshooting#Theinsideofthefreezer
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Sep 01, 2010
What could cause a loud clicking noise from engine 2001 volkswagon jetta 2.0 (automatic)
check that a valve rocker has not jumped off a valve end and is pressing down on the valve spring retainer.
Aug 10, 2014 | 2001 Volkswagen Jetta TDI
Replaced viable but no water filling just clicking noises
DISCONNECT THE ELECTRICITY , DISMANTLE THE INLET WATER HOSE CHECK THE WATER COME OUT, CHECK THE VALVE STRAINER ,CHECK THE VOLT ON THE VALVE IF THERE IS , REPLACE THE VALVE
Apr 02, 2014 | Frigidaire ATF6000ES Front Load Washer
I have a maytag dual cool side by side fridge, recently the ice maker has reduced ice production and the ice cubes are not fully formed ( Almost hollow). When you use the water despenser it makes a...
It sounds like you have a water flow problem. I would inspect the unit for ice building up in or around the freezer fan motor. If the ice is forming in side the freezer, the trouble could the a restriction in the fill tube. But this does not affect the water dispenser. The noise you hear could be the water line moving when water flows through the line, or your water valve itself could be the problem, like the valve shutters when in use.
The valve is easy to check, its located behind the unit in the back left corner. Remove the screw holding the valve in place, while dispensing water hold the valve and see if the issue is only the valve. If the valve is the issue this could cause both problems you have. Part number 67005154
Water Valve
Good Luck
Aug 21, 2011 | Maytag Refrigerators
Noise in the water heater valve. How do I fix it?
Valve is not identified.
Cold water shut-off valve, TP valve, check valve, mixing valve, drain valve are the usual suspects associated with electric water heater.
Gas water heater has additional valves: gas shut off valve and gas control valve thermostat.
Check valve, TP valve and mixing valve probably need replacement.
If drain valve is leaking, put garden hose cap over end.
Shut off valve probably has a bit of blockage, or is not completely open. Try closing and then opening shut-off valve all the way, and if problem persists, replace or clean out valve.
What kind of noise? Are you sure the noise is from a valve or is it inside the tank caused by sediment build-up inside of tank?
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/How-to-replace-TP-valve.html
http://waterheatertimer.org/images/Water-heater-with-mixing-valve-300.jpg
Jul 04, 2011 | RTO Bradford White M-1-20U6SS 19 Gallon...
Water dispenser is releasing water sporadically. I took filter out thinking it was clogged, but water is still coming out in interrupted jets. and there is noise from the bottom of the fridge. The noise is...
hi ... it sounds like a bad water valve. check with a volt meter if u are gating power to the water valve when water is coming out if not you have a bad water valve. if it doesnt do it write me back and i will help you.
Apr 21, 2011 | Whirlpool Refrigerators
The water pipes have been freezing up for the past two nights, got them thawed out, and started a load of laundry set on cold. Washer started normal, it made a small click noise as allways, and the water...
Have you taken the hose off of the back of the washer and checked to see if you are getting water to that point. Also check the inlet screen on the fill valve to see if it is clean.. You may need to replace the fill valve. There may be a screen in the inlet of the hose at the shut off valves.....So check both ends of the washer hose..... I would check the hoses first before I would replace the fill valve....Hope this helps
Feb 12, 2011 | Maytag Washing Machines
Turn on dishwasher hear noise solenoid clicks water valve works but no force of water to turn tines and no clean.
Sounds like you may have a bad solenoid valve. you can check this by opening line that feeds the valve to see if you have sufficient water flow. GET SOME TOWELS READY THIS MAY GET A LITTLE MESSY!
  1. turn off the water valve that feeds the dishwasher.
  2. remove the line to the dishwasher solenoid valve.
  3. slowly turn water back on that feeds the dishwasher.
  4. verify sufficient water pressure flows onto the towels.
Dec 30, 2010 | KitchenAid 24 in. KUDP02SR Built-in...
No water
Problem one : check to see if the float switch is stuck in the up position. The float is located usally in the front right or lift corner. Moving it up and down should make a clicking noise. If no clicking noise is heard. Remove front kick plate. (4 screws) and check switch with electrical meter. If still no water check to see if there is voltage to water inlet valve. If there is power to the inlet valve and still no water. Replace water inlet valve. There is two screws holding the valve in place and a coper line to the valve and a black rubber hose on the top of the valve held on with a hose clamp. Always shut the power off to the appliance before replacing any parts for safty.Make sure you shut the water off before removing valve.
Dec 27, 2009 | Kenmore Dishwashers
My Hotpoint refrigerator (HSS25GPJ) stopped dispensing water from the front. What is the problems and how can I fix it?
There are 2 water valves located on back of refrigerator. one controls the water to ice maker and the other sends water to the water dispenser. The valve could be bad or the dispenser control on front could be defective. The first thing to do is check the water valve on back. When pressing the dispenser does the valve click or make a noise? Let me know, Sea Breeze
Mar 27, 2009 | Refrigerators
Overheating and now engine 'clicking noises.
possible causes of overheating are, dirty cooling system, clogged radiator, bad thermostat. Use only distilled water with a good quality coolant.
still overheating? have your top head checked - warped head, valves, valve seats, etc. You might need to have your engine's compression checked if it is still within specs.
Sep 24, 2008 | 1995 Jeep Cherokee
GE (PSS26MSRSS) Side by Side Refrigerator Logo
169 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
