Question about Dryers
My whirlpool dryer wont continue to start when I remove my finger from start button
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Sep 01, 2010
I have a quiet pak 2 Kenmore. When I depress the start button the drum works but there is no heat. I stops workin when I take my finger off the start button. Model 110.73932102
I looked up the model number. You have a 90 series dryer made by whirlpool. You need to take it apart and clean it up, cheack all limits and safetys for continuity. I beleive you have a bad motor If the drum turns and the belt is not broken when you release you button it stops that is either the start switch or the motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2014 | Kenmore Dryers
Whirlpool dryer did not work when press start button, it beeps twice
Remove the 2 screws that hold the front bottom kick plate in place and remove the panel. Check the "thermister" located on the blower housing for continuity. If it is bad, here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 18, 2012 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer (model LER7646DQO) wont start when the button is pushed; additionally the timer does not continue to run when the dry with the dryrt off
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Dryer wont react when hit start button
HI, Sounds like Normal 0 , UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
a fuse. Try this,
May 30, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wont keep spinning without me holding the start button down
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Kenmore 64902 Electric Dryer
Whirlpool dryer
Yes it can at times. It has been my experience. This thing may be falling apart on the inside. Just replace it before it gives you further problem. There is more heat and resistance there at the contacts. While you are replacing it, check the other things as well. It seems like you have a good eye for this anyway.
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't start
I believe you have lost a leg of power.Check you breaker and then the wiring in the back of the dryer.
Jan 09, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Dryers Experts
