Question about GE Spectra JGBP30 Gas Kitchen Range
Oven and broiler will not light.
My GE Spectra XL 44 range has the same problem. Oven nor broiler will not light. Purchased unit 2001, Had to replace bake igniter already once in 2003.Also, range top burners must be lit most of the time with matches. Clicking noise is very faint sometimes and once it is lit it will click normally. Simmer burner is so low it is not worth using. Of course it is out of warranty.Very disappointed and inconvenienced.
  • 2 more comments
  • mom of 8 Dec 28, 2008
    Thank you. My husband replaced the oven burner ignitor(the unit that makes the orange glow on start up) and it seems to be working fine now. But the top burners still need to be lit with matches on occasion and as I said before, the simmer burner is so low, it's not even worth using it.I appreciate your input, even if it is a bit late.
    Have a Happy 2009!
    By the way, the broiler unit turned out to be fine and working, I was mistaken about that. It was only the oven burner that was inoperable.
    You're very welcome. How about the burners needing to be lit at times? Also, if I turn on the stove burners, sometimes they will click very quietly, but once I light them or they light on their own, the clicking gets louder until I turn it to the flame height I desire. And how about the very low simmer burner. Do you have any ideas or suggestions for those 3 issues? What could cause these things?
    Thanks again!
  • mom of 8 Dec 29, 2008
    Hey, nothing wrong with constructive criticism. I probably am guilty of not taking the burners apart and cleaning them frequently enough. I'll show your suggestion to my husband regarding the simmer burner; He can fix pretty much anything once he knows how it ticks.
    You take care and thanks again!
  • GE Master
  • 5,568 Answers
You've probably done this by now since your message is May (makes us a May-December couple??) but wanted to write that the transformer that produces the park for ignition has failed.  I don't know how accessible it is in your unit, if you check on Sears website under Parts with your model # in hand, they could well have an illustrated breakdown of your range which would give you an idea of how difficult the replacement might be.
Posted on Dec 28, 2008
  • Steve Allison
    Steve Allison Dec 28, 2008
    Thanks for the feedback, it may aid others too.
    I had forgotten that the ovens use mostly 'surface' ignitors just like gas dryers rather than the spark gap used on the burners.
    Thanks for the New Years wishes and the best to your family too for the future.
  • Steve Allison
    I suspect ranges are much alike since some things that worked well a half-century ago, still work today.
    Pulling any of our stovefront knobs off and peering with a flashlight into the shafts, one can clearly see a very recessed small slotted adjustment.
    This sets the flame height affecting mostly the lower setting.
    However, it will take a very long, small shaft screwdriver to reach the adjustment.
    Since the adjustment runs through the center of the shaft, it may feel (because it is) 'gummy.'
    On your ignition problem; this is done with high voltage on the order of several thousand volts as the gap is several millimeters and must be to offer enough of a spark front to the gas streaming toward the gap to ensure ignition.
    Not to criticise your housekeeping, but do you remove the burner parts for cleaning?
    If they get contaminated with any burned residue, the spark may not be happening where it is needed.
    On our simmer burner, the port allowing a path to the spark gap was actually too large and I finally caught it blowing the ignited gas away from the burner.
    I cut an 1/8 inch length of copper house wire (12 gauge) and tapped it into the channel for the spark gap, reduced the gas flow toward it and it has been fine since then.
    If was a brand new range in a new house and I just did not want to have anyone tramping through if it was something I could solve on my own.
Broiler works but oven does not ge xl 44 model JJBP24BEA2WH serial LV201917P Is this worth fixing?
Hello-  Yes if it's the igniter for the oven burner. The lower burner may light, but if igniter is bad, gas flow will not increase, causing under-temp condition. The part is available for 40-75$, and is fairly easy to install. Part is accessed by removing drip pan at bottom of oven. Gas ranges last longer than electric if the self-clean 'function' is avoided. Go ahead and fix it!  Let me know if this info helps-- have more if needed.   Thanks-  Ed
Mar 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Oct 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't light
Probably a bad oven igniter. Remove oven floor then remove flame spreader. Turn oven on and see if igniter glows. If it does and still doesn't light gas, it's probably weak. Replace the igniter!
If it doesn't glow, remove and take to your parts store. They should ne able to check it to see if it's opened up.. If so replace it!
Nov 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
769 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
